Thread: Exhaust Leak, Needing new Converter & Resonator
Results 1 to 12 of 12
  1. #1 Exhaust Leak, Needing new Converter & Resonator
    SE Level Member void33's Avatar
    Jan 2013
    Chicago
    2000 Grand Prix GT.
    220,000 miles.
    A couple weeks ago I replaced an old rusty o2 sensor (downstream) and it took some elbow grease. Turns out I put a nice gap between the converter and resonator when kicking and pulling to get the old sensor loose. The result is a big bad exhaust leak. I fixed it with exhaust cement putty stuff which held for a few weeks but is really starting to fall apart now.
    Anyways, shop tells me they can't splice it with a new pipe because of too much rust on the converter and resonator but they will let me bring my own parts. I am only trying to get 6-18 months out of this car before it's time to sell/scrap.
    So, my first question is if I can safely go with the cheapest resonator and cheapest converter found on RockAuto and expect (mostly the converter) to last 6-18 months. My second question is how the resonator attaches to the rest of the exhaust. Shop told me it bolts on but it doesn't look that way to me. Thanks!
  2. #2 Re: Exhaust Leak, Needing new Converter & Resonator
    Kemmerer, Wyoming
    the resonator does bolt on on one end. you can see from this picture.
    https://drive.google.com/file/d/0B6K...ew?usp=sharing
    here is another picture that shows the resonator better.
    if you havent bought the catalytic converter yet and want an oem one I have that I've had since I put headers on. it is in good shape as far as I can tell, and would need to be welded in. if you are interested, I will take some pictures.
  3. #3 Re: Exhaust Leak, Needing new Converter & Resonator
    Jan 2013
    Chicago
    I'll consider it, thanks SgtMarshal.
    I know the resonator bolts on to the converter with the flange at the front end but I'm concerned about how it attaches to the rest of the exhaust on the rear end. My exhaust is rusty, if it needs to be welded they might make me replace the rest of the exhaust too... See what I mean?
  4. #4 Re: Exhaust Leak, Needing new Converter & Resonator
    Kemmerer, Wyoming
    you can get the whole catback minus the converter, resonator, mufflers for 120 if you just get a single pipe back, check it out:
    http://www.mandrelexhaustsystems.com...rand-prix.html
  5. #5 Re: Exhaust Leak, Needing new Converter & Resonator
    Jan 2013
    Chicago
    That seems illegal, no? That would basically replace the converter & resonator all the way back to the mufflers, right?
  6. #6 Re: Exhaust Leak, Needing new Converter & Resonator
    Kemmerer, Wyoming
    your car won't pass emissions without a converter, and if you don't run a resonator, your car will be loud and sound horrible.
  7. #7 Re: Exhaust Leak, Needing new Converter & Resonator
    Jan 2013
    Chicago
    That's what I thought. I don't want to go that far.
    I'm really just curious if the cheap-o converters will be good enough for 6-18 months and how the resonator attaches to the rest of the exhaust at the rear end.
  8. #8 Re: Exhaust Leak, Needing new Converter & Resonator
    Kemmerer, Wyoming
    you might be able to crawl under and look up at it, that would be the best way I could recommend.
  9. #9 Re: Exhaust Leak, Needing new Converter & Resonator
    Jan 2013
    Chicago
    Yeah, I'll probably do that. I don't have welding equipment so if it's welded I might be screwed. Any recommendation on the cheap converters?
  10. #10 Re: Exhaust Leak, Needing new Converter & Resonator
    Antioch, IL
    I have this laying around doing nothing 2.5" catback magnaflow "reso", flowtech afterburner mufflers, stainless 3.5" tips $150, have a shop weld on a cat and walla.
    20150817_171022 by Corey S, on Flickr
    20150817_171050 by Corey S, on Flickr
    2009 Challenger SRT8
    Expert at being gay.
  11. #11 Re: Exhaust Leak, Needing new Converter & Resonator
    Jan 2013
    Chicago
    Thanks for the offer ItHurtz, I'll consider it. That will only save me money if they want to replace everything behind the resonator, which they may.
  12. #12 Re: Exhaust Leak, Needing new Converter & Resonator
    Jan 2013
    Chicago
    So just to disclose, this is what I ended up ordering, will be taking it to the local shop to have them install. Thanks again for everyone's help!
    Walker 54627
    Dynomax 31532
    Walker 35352
    Walker 31605
    Walker 21383
  1. Needing Exhaust Tip Recommendations
    By edwards99 in forum Visual/Body Modifications
    Last Post: 05-16-2016, 04:05 PM
  2. Exhaust leak from resonator
    By 97GPJJ in forum Introductions/Noob Questions
    Last Post: 02-16-2013, 03:33 PM
  3. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
  4. resonator, exhaust help
    By BIGTMANE in forum General Tech Discussion
    Last Post: 08-15-2010, 01:35 PM
  5. resonator exhaust question!
    By colindunn in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2010, 03:30 PM
