Thread: Best spark plugs to use?
Results 1 to 3 of 3
  1. #1 Best spark plugs to use?
    Sep 2012
    fort Wayne, in
    So been doing a decent amount of maintenance on the car. Just had the upper and lower intake gaskets redone, valves cleaned out lower intake completely cleaned, fluids changed brand new intake manifold and added a hv3 and it's been running great but between 2nd and 3rd gear right before it shifts if I'm WOT it feels like it stumbles so I'm thinking of changing out the plugs. They are about 3 years old so thought of changing them out. Only check engine light that's on is po446 which says the fuel level pressure sensor needs replaced because the evap canister purge vent is blocked so I'm starting with new plugs and going from there. The check engine was on before I did the mantience
  2. #2 Re: Best spark plugs to use?
    Factory plugs would be the best. AC Delco 41-101's.
  3. #3 Re: Best spark plugs to use?
    Jan 2017
    Lehighton, PA
    Agreed.. My car was used and abused before I bought it....never maintained in its life....and I replaced everything with AC Delco plugs...wires...and a fresh fuel filter....and I went from 14-15mpg...to now...WITH the A/C on....I'm up to 22mpg. And she purrs like a kitten....and has the get-up-and-go like I think she did when she was new. I definitely always recommend going OEM when it comes to plugs.
  1. Spark Plugs on '04
    By 04GT2 in forum General Tech Discussion
    Last Post: 08-10-2016, 12:34 PM
  2. Replies: 34
    Last Post: 05-28-2012, 10:53 AM
  3. Spark plugs?
    By Mad Monkey in forum General Tech Discussion
    Last Post: 06-16-2011, 07:32 PM
  4. spark plugs
    By silverstreak in forum General Tech Discussion
    Last Post: 08-01-2009, 06:09 PM
  5. What spark plugs?
    By Dwhip in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-25-2009, 08:21 PM
