Thread: Starting Issue
Results 1 to 18 of 18
  1. #1 Starting Issue
    Jul 2010
    Coquitlam,BC,Canada
    Vehicle: 2002 GT 3.8L n/a
    Issue: When starting, warm or cold, sometimes she fires then stalls on the first crank. Second crank she fires right up.
    This has been a minor issue for about a year or so as it happened only once in a while. Over the past 2-3 months, it is happening more frequently, and most of the time the second crank barely gets her running; low rpm and mild sputtering. After about 10 seconds she is running fine.
    No DTC's at all.
    Any thoughts or ideas where to start? In my head I think it is a bad or weak sensor, but that's just a random guess. Maybe that K&N CAI is letting to much air in? LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  2. #2 Re: Starting Issue
    Jul 2010
    Coquitlam,BC,Canada
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  3. #3 Re: Starting Issue
    Double prime the fuel system and see what happens.
    Fuel pressure regulator could be going bad.
  4. #4 Re: Starting Issue
    Jul 2010
    Coquitlam,BC,Canada
    So, when I remember to do this, it does start right away.
    When cold, starts right away.
    I got gas today, and she started right up after I filled up. Not sure if this has any relevance.
    When I don't double prime, she can take 3-5 times before starting, and then I get the light wiff of fuel.
    I will swap out the regulator and see if it fixes the problem.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  5. #5 Re: Starting Issue
    Jul 2010
    Coquitlam,BC,Canada
    Double prime? As in spray starting fluid in the intake? As well as let the fuel pump do its thing?
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  6. #6 Re: Starting Issue
    No, just prime the fuel system like normal but twice.
    Turning the key to ON will prime the pump/lines for 2 seconds, then stop. Do that twice and see if it helps any.
  7. #7 Re: Starting Issue
    Jul 2010
    Coquitlam,BC,Canada
    I will give that a shot. Thanks.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  8. #8 Re: Starting Issue
    GT Level Member brettstoner's Avatar
    Jul 2014
    Toledo, OH
    Start with some diagnostic work. Check for spark. Check for fuel.
    Spark
    Hook up a timing light and have someone start it while you check each wire for strong rhythmic pulses. Or use a scrap spark plug and test each wire grounding out the sparkplug. Use electrician's gloves or you will get a good jolt if it grounds through you instead! LOL
    Fuel
    Measure fuel pressure while sitting (slow leakdown), while starting, and while idling. Could be pump going out or losing prime. Pull each injector and use a tester to measure resistance of injector and if it is getting pulses from ECM.
    Of course all the usual maintenance stuff. Good plugs, wires, O2, cleaned TB, connections clean and tight, etc need to be done and ruled out.
    04 GP GT- top swap, VS cam, 2.8 pulley, E85, headers, 60 injectors, TEP 3:29 trans, Racelogic Traction Control, ZZP dyno tuned.
  9. #9 Re: Starting Issue
    Jul 2010
    Coquitlam,BC,Canada
    Thanks brettstoner .
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  10. #10 Re: Starting Issue
    Quincy, Mass
    Before you go buying an expensive regulator, pull the vac hose off of the regulator and see if its wet with gas. If it is then replace it. If not then it might be the pump going out.
    No more GP 04 Impala SS Indy:
  11. #11 Re: Starting Issue
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by Swiggles View Post
    The hose is dry inside and out and there doesn't appear to be any remnants of fuel.
    I can't even find a regulator that looks like mine.
    I've also noticed that if I hold the key and crank for an extra second or so, she seems to start ok.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  12. #12 Re: Starting Issue
    Sep 2015
    Lansing, Michigan
    fuel pump getting weak...
  13. #13 Re: Starting Issue
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by tom5170 View Post
    This is in the back of my mind. If the rain ever stops I will get to some testing.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  14. #14 Re: Starting Issue
    Quincy, Mass
    Check valve in the pump might not be doing its job anymore.
    Here's the regulator if you are on stock rails
    Standard Motor Products PR190 Pressure Regulator https://www.amazon.com/dp/B000C81MG6..._6Ukoyb79NTQK7
  15. #15 Re: Starting Issue
    Jul 2010
    Coquitlam,BC,Canada
    Is it mounted on the front fuel rail, on the drivers side? If so, mine is different and I can't find one like it (has the schrader valve on it.).....
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  16. #16 Re: Starting Issue
    There is no valve on the regulator.
    Look at that picture, you can see the snap ring holding the regulator is place. Remove the snap ring and the FPR comes straight out the top.
  17. #17 Re: Starting Issue
    Jul 2010
    Coquitlam,BC,Canada
    Thanks ffdp. It is supposed to be sort of not raining on Sunday, so I will take a closer look.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  18. #18 Starting Issue
    Quincy, Mass
    It can be a pain getting it out, twist and wiggle, and the new can be a pain going in because the oring is new, a little oil on the rings will help them slide in.
    That valve is mounted on the outside of where the regulator sits in.
  1. 04 GTP- starting issue
    By jmsgtp04 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-30-2014, 06:42 PM
  2. Starting issue
    By Zach Chapman in forum General Grand Prix Discussion
    Last Post: 12-25-2012, 10:11 AM
  3. Please someone help me out here, starting issue.
    By Brickie in forum General Tech Discussion
    Last Post: 01-12-2012, 12:10 AM
  4. Odd Starting issue
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2011, 11:04 AM
  5. 97 Gtp starting issue
    By DukesGTP in forum Off Topic Discussion
    Last Post: 10-29-2010, 06:35 PM
