Thread: Hesitation at low RPM
Results 1 to 2 of 2
  1. #1 Hesitation at low RPM
    May 2016
    Lansing
    So I had an issue before with the car hesitating while accelerating, I replaced the plugs and wires and everything was fine for a while. Now the car hesitates only when in lower RPM's usually between 40 and 80 MPH (1800-2800RPM). I'm not sure what it could be but I have a few ideas. First the Mass Airflow sensor is used from a junkyard according to the previous owner, so it's quite possible that is the culprit. Second is the MAP sensor, I noticed that the clip holding the sensor is broken and the sensor itself is cracked. Along with that I saw some oil pooled on the back of the lower intake manifold. It seemed to be leaking from the intake manifold or valve cover. Do you think this would cause a bad enough vaccum leak to make the car hesitate? Third, a check engine light came on for the (vapor canister). I don't think this would cause a problem but I'm planning on replacing it anyway. Anyone know a way to test the MAP and Mass airflow sensors?
  2. #2 Re: Hesitation at low RPM
    A live data scanner could lead you to a vacuum leak of if the MAP sensor is reading incorrectly.
    I'd clean the MAF sensor just because though.
  1. Bad Hesitation
    By Tate in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-26-2015, 03:24 PM
  2. hesitation
    By Toms04compg in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-14-2013, 09:43 AM
  3. hesitation
    By easymoney in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2012, 10:54 PM
  4. 01 GTP Hesitation
    By chefchicago in forum General Tech Discussion
    Last Post: 03-21-2012, 09:06 PM
  5. Hesitation
    By polo3433 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-15-2010, 02:09 PM
