Thread: Fuel injector O-rings
Results 1 to 3 of 3
  1. #1 Fuel injector O-rings
    SE Level Member 01gtxcoupe's Avatar
    Dec 2014
    Racine, WI
    Just a quick question for you guys. I am going to be changing LIM gaskets on a 2001 GT with a stock L36. While I am doing this I am going to change out the fuel injector O-rings as well. Are both rings on each injector the same size? I'm talking the side of the injector that goes into the fuel rail and the side that goes into the LIM. I want to make sure I order the correct parts.
    Thanks!
  2. #2 Re: Fuel injector O-rings
    if you but the magnum kit on rockauto it comes with the lower o rings, the upper / fuel rail side are not the same, you'll need to go to a part store and see what they give ya.
    removal of o rings, cut them then remove, new ones oil them and roll them on wet with oil. make them wet with oil again when you push them back in the lim and clean the holes they live in as well.
  3. #3 Re: Fuel injector O-rings
    Dec 2014
    Racine, WI
    Awesome thank you! Rockauto does also have a acdelco set as well that comes with 8 upper and lower seals for $10 http://www.rockauto.com/en/moreinfo....id=473&jpid=10
  1. P0171, Fuel Injector O rings?
    By Fahrenheit in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-04-2013, 07:06 AM
  2. 1997 Grand Prix GTP (Super Charged) Fuel Injector O-rings.
    By Ravenwald in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-23-2012, 06:44 PM
  3. Fuel Injector O-Rings
    By bobabooie in forum General Tech Discussion
    Last Post: 04-07-2011, 07:08 AM
  4. Injector 0-Rings
    By trailshredder in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-28-2010, 08:55 AM
  5. Should I replace the injector o-rings?
    By Infinity9999 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-04-2009, 11:16 PM
