Thread: 98 Grand Prix GT Coupe: Bad Main Bearing Rebuild Project
Page 3 of 3 FirstFirst 123
Results 41 to 53 of 53
  1. #41 Re: 98 Grand Prix GT Coupe: Bad Main Bearing Rebuild Project
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    The adapter plate allows you to bolt an earlier TB to a later intake, and most people use it in order to put a 04+ Gen 5 supercharger on their 97-03 L67 engine. The L26 TB is drive by wire, yours is cable driven. You could use an L67 TB however, IIRC they have the same sensors and everything. Plus the adapter plate is easier to find.
    you can use the L26 LIM, and modify it while you have it apart.
    http://www.grandprixforums.net/threa...w-to-Mod-a-LIM
    Some of that won't apply, since the engine is N/A, but the first two steps will help if you ever have to pull the TB off and don't want to spill coolant, and prevent the TB adapter from leaking.
    Also the L26 heads are slightly better than the L36, so keeping those will be a good idea.
    The only other difference between the two is the alternator bracket, depending on which alternator you will use, you will need the corresponding bracket.
    There's a few other things, using the aftermarket aluminum coolant elbows that go into the alt bracket, the later design steel LIM gaskets, other small upgrades/preventative maintenance... By the end of this swap, that car is going to be pretty sweet.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  2. #42 Re: 98 Grand Prix GT Coupe: Bad Main Bearing Rebuild Project
    Jul 2016
    Texas
    With daughter doing the work, we drained the coolant, that went well.
    Then we went to drain the oil, and out came a milk shake.
    She said "Dad! The oil isn't supposed to look like that, is it?"
    Now we know the most likely cause of bearing failure.
    We grabbed a sample of the oil, and I thought I would see bearing material, but nothing showed up even after running a magnet through it.
    Maybe the previous owner changed the oil out and/or cleaned out the pan?
    New to us engine will be delivered tomorrow.
  3. #43 Re: 98 Grand Prix GT Coupe: Bad Main Bearing Rebuild Project
    bearings are copper, drain the oil through a rag or coffee filter, you might see some flakes.
    look under the upper intake at the egr for a hole. that can cause coolant to get in the engine. if you find a hole its best to jsut get a new intake.
  4. #44 Re: 98 Grand Prix GT Coupe: Bad Main Bearing Rebuild Project
    Oct 2014
    Frederick, MD
    scotty, the new intake is pointless... lol
  5. #45 Re: 98 Grand Prix GT Coupe: Bad Main Bearing Rebuild Project
    they need a intake, or get a adapter plate and use the l26 intake, the cost is about the same.
  6. #46 Re: 98 Grand Prix GT Coupe: Bad Main Bearing Rebuild Project
    Oct 2014
    Frederick, MD
    I say adapter plate, aluminum > plastic anyday
  7. #47 Re: 98 Grand Prix GT Coupe: Bad Main Bearing Rebuild Project
    Jul 2016
    Texas
    Previous owner has a brand new dorman intake on the outgoing engine, but I'm still leaning toward an adapter plate and keeping the aluminum.
    Where do I order one from?
  8. #48 Re: 98 Grand Prix GT Coupe: Bad Main Bearing Rebuild Project
    Oct 2014
    Frederick, MD
    there's a guy on here sells hybrid phenolic intercoolers, along with adapter plates and many other things, his username is sseilmnop
    send him a pm, he'll help you out.
    another place would be zzp, but they are iffy on the quality. Sometimes its decent, other times its total crap.
  9. #49 98 Grand Prix GT Coupe: Bad Main Bearing Rebuild Project
    LaBarge Supercharged sseilmnop's Avatar
    Mercer, Pa
    This is the adapter. I sell them on eBay.
    https://www.ebay.com/itm/111478776645
    Adapters, Phenolic Intercoolers, Supercharger Parts & TVS2300
    http://stores.ebay.com/QualitySuperchargers
  10. #50 Re: 98 Grand Prix GT Coupe: Bad Main Bearing Rebuild Project
    Kemmerer, Wyoming
    just so you know, swapping from an L36 upper intake to an L26 upper intake is not a direct swap, and some modification is necessary. I don't remember what I had to do to make it work.
  11. #51 Re: 98 Grand Prix GT Coupe: Bad Main Bearing Rebuild Project
    Jul 2016
    Texas
    Thanks for the heads up SgtMarshal
  12. #52 Re: 98 Grand Prix GT Coupe: Bad Main Bearing Rebuild Project
    you would need to block off the evap port on the l26 upper, then use the adapter plate and your l36 tb on it, run your cars evap like normal off the tb port.
    pcv hose now will go to the vac port on the tb spacer/adapter.
  13. #53 Re: 98 Grand Prix GT Coupe: Bad Main Bearing Rebuild Project
    Oct 2014
    Frederick, MD
    You should polish it up, it's a modded car now... lol
  1. Main or rod bearing problem!!
    By MidnightBlue in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-12-2012, 10:57 AM
  2. 99 Grand Prix GT coupe PROJECT CAR?
    By Solid Steel in forum General Grand Prix Discussion
    Last Post: 04-27-2012, 08:24 AM
  3. Main engine bearing failure
    By 03grandprixgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-14-2011, 08:50 PM
  4. Main bearing caps
    By btamayo in forum General Tech Discussion
    Last Post: 09-19-2010, 03:01 PM
  5. Bad main bearing?
    By Teancum in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-08-2010, 11:05 AM
