Thread: Lifter Tick Questions
Page 3 of 3 FirstFirst 123
Results 41 to 48 of 48
  1. #41 Re: Lifter Tick Questions
    its not a o ring, its just a rubber grommet the hose plastic end pushes into on the booster.
    get some carb cleaner, spray all injectors and vac lines, all gaskets areas, uim, the egr tubes, tb gasket, lim gaskets. aka the whole top of the engine.
    if carb cleaner spray is used and it hits a leak area the idle will jump up. if you use brake cleaner the idle will drop
  2. #42 Re: Lifter Tick Questions
    next oil change do a mix of 40 and 30 weight oil. 3 qts of 5-40, 2 of 5-30. that shut my lifter tick up when it was acting up in the old engine. come winter times oil change id go back to 30 weight only.
    mine would do 3 to 5 loud claps, more then a tick, then just stop. only on a cold start, like it sat over night.
  3. #43 Re: Lifter Tick Questions
    GTP Level Member Kaiser Pontiac's Avatar
    Jun 2015
    Land of 10,000 Salted Roads and Rusty Cars.
    Thanks for the tips Scotty! Yeah, mine will only do it if it's been sitting for a good day or so. Just a bunch of clitter clatter for 5/8 seconds.
    Got a new O-ring, didn't fix it, found the leak, coming off of the EGR tube....,probably cracked? Can I drive it a bit like this, like, that's okay, right?
    06 LaCrosse 57-79k sold;99 4dr GTP 134-138k sold;98 2dr GTP 183k parted;98 Regal 166-184k;04 GT2 204-206k sold;04 GTP 170-175k sold;09.5 G8 GT Sport 145k;09 G8 78-84k+;08 Prix 164k sold;06 Prix 168k sold;02 Regal 92k;09 G8 103k parted;04 GTP SpEd 139k parted;04 GTP 205k;'09 G8 105k parted;06 Prix 230k;04 CompG 138k
  4. #44 Re: Lifter Tick Questions
    smear the egr tube with orange rtv. should seal it up.
    you can drive it sure, but its a vac leak, it should be fixed.
  5. #45 Re: Lifter Tick Questions
    Jun 2015
    I got some red high-temp, that work too?
  6. #46 Re: Lifter Tick Questions
    it should.
  7. #47 Re: Lifter Tick Questions
    Jun 2015
    perfecto - thanks Scotty
  8. #48 Re: Lifter Tick Questions
    Jun 2015
    So, I used some JB-Weld on the tube, but I couldn't get to the whole area where the leak is coming from (UIM, LIM, piping....) - still leaks, so, have to take the retarded thing off and just JB-Weld the crap out of the whole tube.
    Also, when I started it up this morning the lifter tick was much longer than normal, ~25 seconds..... Kinda has me worried. Might do the oil change right now. BTW, I'm running 10w-30, ATM.
  1. Injector or lifter tick
    By Alexgp in forum Introductions/Noob Questions
    Last Post: 05-14-2016, 08:45 PM
  2. Lifter tick or something else?
    By 04gtpnoob in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-19-2016, 11:14 PM
  3. 3800 lifter tick
    By redynscire in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-27-2011, 08:00 PM
  4. Lifter tick?
    By My GTP 97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-22-2010, 01:03 PM
  5. Lifter Tick
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-21-2008, 06:43 PM
