Thread: Engine noise/movement 05 GP
Results 1 to 7 of 7
  1. #1 Engine noise/movement 05 GP
    Jan 2016
    Florida
    I have a 2005 Pontiac GP Base. Usually when cold it makes an odd noise at idle park or drive that sounds like the video below at 30 and 38 or so. You can hear the sound in the background slightly and is very noticeable when I shift from park to reverse and drive to reverse (at 30-40 seconds). Also is that much movement normal for the engine?
    https://youtu.be/9A0di8fMxhg
  2. #2 Re: Engine noise/movement 05 GP
    Looks like it is time to fix your motor mount.
  3. #3 Re: Engine noise/movement 05 GP
    Poor camera/audio do kinda make it hard to hear things, they just sound worse than they really are to me. I can't tell if it's engine related or pulley related. Maybe a lifter noise??
    You could try some trans fluid in the oil to help clean things up on the inside if you think it's a valvetrain clatter noise.
    As for the movement, I bet the passenger side motor mount is puked. That's alot of extra movement for an engine to have, I'd replace it if you never have before or atleast inspect it.
  4. #4 Re: Engine noise/movement 05 GP
    Jan 2016
    Florida
    Listen at 36 seconds, so as I shift from drive to park. Its a hollow sound
  5. #5 Re: Engine noise/movement 05 GP
    It could be the motor mount making the noise. Check it I bet it looks like this.
    Check the mount on the other side as well.
  6. #6 Re: Engine noise/movement 05 GP
    Jan 2016
    Florida
    Ok I'll check when I can. There is a lot of movement on the upper mounts, should those be replaced?
  7. #7 Re: Engine noise/movement 05 GP
    Check the condition of them. If the rubber isn't torn flip the mounts. Someplace on here there are instructions on how to flip the mounts. I'm on my phone atm, and can't remember where it is.
  1. Engine movement
    By Dee23 in forum General Grand Prix Discussion
    Last Post: 10-06-2014, 01:48 AM
  2. Noise on first movement of car and when braking on slick surface
    By ImColeTrickle in forum General Tech Discussion
    Last Post: 02-01-2012, 11:21 PM
  3. cv shaft and joint movement
    By Scottydoggs in forum General Tech Discussion
    Last Post: 09-24-2011, 09:16 AM
  4. Grinding noise in reverse, then no movement
    By chantspel in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-06-2010, 08:08 AM
  5. Movement in the other direction!
    By GPGT08 in forum Tires & Wheels
    Last Post: 07-01-2008, 05:06 PM
