Thread: Valve Cover Gaskets
Results 1 to 4 of 4
  1. #1 Valve Cover Gaskets
    Mar 2016
    Richmond, Maine
    2004 Grand Prix. NOS factory engine installed 2 years ago. Now the valve cover gaskets are leaking already all over the garage floor. I understand there is a redesigned gasket set. How do I know I am getting the right ones? Does anyone know the part number of the ones that will not leak again? Thanks.
    -John
  2. #2 Re: Valve Cover Gaskets
    Get the felpro ones from either advance or rockauto
    04 Comp G.
  3. #3 Re: Valve Cover Gaskets
    if its the front call a dealer and set up an appointment .
    and you say puddles on the floor, never seen a v/c leak that bad. my moneys on the oil pressure sensor is leaking. pass side of the engine. near the oil filter.
  4. #4 Re: Valve Cover Gaskets
    Mar 2016
    Richmond, Maine
    and you say puddles on the floor, never seen a v/c leak that bad. my moneys on the oil pressure sensor is leaking. pass side of the engine. near the oil filter.[/QUOTE]
    Is the pressure sensor leaking a known problem? That's where all the oil seems to be coming from. The heads under the valve cover gaskets are damp, but not to the extent where the oil filter is.
    -John
  1. Valve cover gaskets
    By 94grandprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-03-2014, 08:09 AM
  2. Valve cover gaskets
    By hockeybawler in forum General Tech Discussion
    Last Post: 05-29-2013, 12:47 AM
  3. valve cover gaskets
    By Jakegday in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-01-2012, 03:59 PM
  4. valve cover gaskets
    By Garrett Mofford in forum General Tech Discussion
    Last Post: 10-15-2012, 03:31 PM
  5. Valve cover gaskets
    By Joe m in forum General Tech Discussion
    Last Post: 11-23-2009, 08:50 PM
