Thread: Running Warm - rad fans never go on high?
Results 1 to 17 of 17
  1. #1 Running Warm - rad fans never go on high?
    Jun 2010
    Montreal, Qc
    Morning all, new member here, just signed up.
    I picked up an '04 Grandprix a few months ago and I've been trying to figure out the cooling system in the car ever since.
    First off, how hot do these engines run? My needle will range between the 3 and 4th tick if i'm stopped long enough in traffic. Seems very warm to me. Forgot to mention - the fans will go on low speed by themselves, but it's not enough to really cool the thing down. With the AC on and the engine running warm I've noticed the fans will hit speed on occasion.
    This is what I've done so far:
    Checked coolant PH - Ok
    Replaced Thermostat
    Replaced Temp Sensor.
    I was going to replace the relay, but then found 3 of them in the car, that stumped me, so i did a little more reading and found if you unplug the temp sensor the fans should go on high as a fail-safe. I tried that and sure enough, the fans go on high. Thats when I decided to replace the temp sensor instead of the relay(s).
    My solution during the warm weather has been to unplug the temp sensor and let the fans run on high, but I'm afraid of burning something out doing that.
    Any ideas would be appreciated!
    thanks all.
  2. #2 Re: Running Warm - rad fans never go on high?
    im not familiar with the 'tick' measurement, but if you figure out the numbering on it you should be running in the 210* area or a little less with the stock thermostat.
  3. #3 Re: Running Warm - rad fans never go on high?
    GT Level Member sic6's Avatar
    san marcos, tx
    Your sender for the temp gauge may not be reading properly. Or its possible you might have air in the cooling system.You should try to bleed out the cooling sstem and see if that stops the issue.
  4. #4 Re: Running Warm - rad fans never go on high?
    GT Level Member hourang's Avatar
    commerce, mi
    do they run on high with the a/c on?
    -Jeff
    98 GTP Black 4dr - fully loaded - short ram intake, tinted tails, hole in resonator.
    sold 98 camaro ss - 6spd fully loaded - cam, intake, exhaust, ford 9in rear 4.11s, 6point chromoly cage, tnt 150shot nitrous, nittos, etc.
  5. #5 Re: Running Warm - rad fans never go on high?
    Jun 2010
    Montreal, Qc
    Bio - I guess I'd have to get a temp gun or something? Unless your gauge is different than mine, the gauge is divided into to 5 sections, by tick marks.
    Sic6 - I bled the system after replacing the temp sensor, I guess it's possible the gauge is reading the wrong temp, but it seems to stay where it should while driving, and I would think the relays should intercept the temp signal and tell the fans what to do prior to the signal getting to the gauge?
    Hourang - Yes the fans have gone on HI if the AC is on.
    I'm stumped.
  6. #6 Re: Running Warm - rad fans never go on high?
    commerce, mi
    Quote Originally Posted by crash2599 View Post
    I'm stumped.
    so instead of pulling the temp sensor just run it with a/c on all the time for now. i would get or borrow a scan gauge that reads live data. you can get one on ebay for $60, i use mine all the time. im not even sure you have a problem.
    -Jeff
  7. #7 Re: Running Warm - rad fans never go on high?
    Jun 2010
    Montreal, Qc
    well, like I said, the AC doesn't *always* put the fans on high, even if it's running warm. I could certainly try running the AC and give it a try when it's running hot.
    Not quite sure what you mean by a scan guage? Could you be more specific as to waht I would search for?
    First off, am I right in assuming the needle should stay relatively stable between the 2nd and 3rd part of the guage once the engine has warmed up?
    Thanks all
  8. #8 Re: Running Warm - rad fans never go on high?
    get a scanner on the car and see what the PCM is reading for temperature.
  9. #9 Re: Running Warm - rad fans never go on high?
    yeah, it should stay stable somewhere 2/3 up on the gauge or so if the thermostat is the stock temperature rating.
  10. #10 Re: Running Warm - rad fans never go on high?
    commerce, mi
    U381 LIVE DATA Scanner OBD 2 Code Reader~OBD2 MemoScan: eBay Motors (item 390202691565 end time Jun-06-10 03:30:27 PDT)
    thats the one i have but any obd2 scanner that does live data should be good. you can also borrow one from an autoparts store, though im not sure if those will have live data or not.
    -Jeff
  11. #11 Re: Running Warm - rad fans never go on high?
    New Jersey
    The gauge will go above the 3rd tick on a hot day. The fans do not kick on until 210-220F. I drive an 06 and noticed the same thing. A 95 Lumina we had ran about the same.
    I run my A\C a lot which runs the fans on low so my temp doesn't usually cross the 3rd tick. however If I turn the A\C off and sit for some time, it will.
    Essentially it hangs where the gauge in this picture is. It will climb slightly above the 3rd "longest line" before the fans kick on with A\C off. It never goes near the red shaded area. When cruising it hangs near center of the gauge due to good flow through the rad.
  12. #12 Re: Running Warm - rad fans never go on high?
    Feb 2016
    Washington, DC
    MrTube, thanks for the clarification! My guage hovers right around that tick as well, so I guess that's normal. But I've noticed that when I get home after driving for a while, I can smell what seems like hot coolant. I don't know if that's new (recently got a coolant flush) or if I just never noticed it before. Anyone else notice that smell when the car is warm?
  13. #13 Re: Running Warm - rad fans never go on high?
    that guy aint logged on in 3 years and this is a 6 year old thread now.........start your own thread with your own issues.
  14. #14 Re: Running Warm - rad fans never go on high?
    New Jersey
    But here I am!
    But I've been driving a Chevy Sonic since 2012. Sometimes I miss my GP.
    Personally, I see no reason to start a new thread. This one still contains the same useful information,
  15. #15 Re: Running Warm - rad fans never go on high?
    Jun 2010
    Montreal, Qc
    Back from the beyond! Have seen many great things in 6 years. . Glad to see my thread has helped some along the way. Cheers.
  16. #16 Re: Running Warm - rad fans never go on high?
    Feb 2016
    Washington, DC
    Haha, thanks. I'm obviously new here.
  17. #17 Re: Running Warm - rad fans never go on high?
    Buffalo
    What a save !
  1. Starts then dies warm
    By trailshredder in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-12-2010, 07:02 PM
  2. diffucult warm start
    By Sowhatsup2000 in forum General Tech Discussion
    Last Post: 07-03-2010, 07:31 PM
  3. Trans does not want to shift out of 1st until warm
    By topswap in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-30-2010, 11:45 AM
  4. warm up
    By grand2000prixgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-15-2009, 09:19 PM
  5. Rough on warm start
    By hacket in forum General Tech Discussion
    Last Post: 03-22-2009, 12:01 PM
