How the hell do you remove the radiator on the driver side from the ac condensor? I'm trying to replace radiator, and I had to lift up on the condensor from the bottom on the passenger side to "unhook" it from the radiator, but how do you remove it from the driver side? I thought the radiator should just pull out. But its hooked to the condensor with the lines attached to it as well. Its on a 06
