Thread: New DP Opinions Please
Results 1 to 20 of 25
  1. #1 New DP Opinions Please
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    I am getting a p0420 code for the cat. I have had the zzp dp on there for 12,000 miles and now its throwing codes. This may also be due to the fact that during those 12,000 miles I had failing LIM gaskets (felpro metal ones) which caused misfires and significant coolant burning. I do need to replace it so the question is do I go and get another ZZP dp or do I get this Walker Ultra one off of amazon.
    http://www.amazon.com/Walker-54627-U...ter+direct+fit
    Or this one
    http://www.amazon.com/Walker-54758-D...ter+direct+fit
    I am not looking into having one welded as the labor rates around here are crazy. I got quoted about $120. Add in a decent cat and now we are more than these direct fit ones.
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  2. #2 Re: New DP Opinions Please
    Spark plug fouler trick... Google it before you spend money on a cat!
    04 Comp G.
  3. #3 Re: New DP Opinions Please
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    your cat isn't necessarily shot. sometimes it takes awhile before they throw a code due to the high flow design. some people get the code right after install , some take a few weeks or months , some never throw a code. i'd make sure the cat is actually bad first. are you getting any symptoms other than the code ? smelly exhaust ? loss of power ?
    have you ruled out the down stream O2 sensor as the source of the code ?
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  4. #4 Re: New DP Opinions Please
    Newnan, GA
    Down stream o2 is bouncing along with the upstream in voltage. 0.1 to 0.9. Seems to be reading well. Car does not seem sluggish per se but my fuel economy is significantly lower.
    It did not do this before the code. Downstream was fairly steady before.
  5. #5 Re: New DP Opinions Please
    Dec 2014
    Maryland
    hmmm..the downstream o2 doesn't affect fuel mileage like the upstream does. if you shut the CEL off does it come right back on. exhaust leaks can also throw the p0420. i had a cracked front mani and didn't know it until i took the heat shield off to install a plog.
  6. #6 Re: New DP Opinions Please
    Newnan, GA
    I assume that a partly clogged cat could affect mileage, but an exhaust leak also could be it. How would I go about checking that? Where are the trouble spots to look at first?
  7. #7 Re: New DP Opinions Please
    the chances of the cat being clogged up in 12,000 miles is unlikely. zzp cat is hi flow too.
    clear the code with a scanner, or unplug the battery for 1.2 hr or so. that will re set the pcm and clear the code. it may never come back on. or maybe in a week.
    if the light comes back on, id toss a fouler on the o2 and see what happens.
  8. #8 Re: New DP Opinions Please
    Newnan, GA
    I've reset 3 times in the past week. Something is definitely up.
    Which non foulers are recommended for our cars?
    Also this fix seems to defeat the purpose of the downstream o2, how would I tell that the cat is bad in the future? Just gotta see if the other symptoms show?
  9. #9 Re: New DP Opinions Please
    Dec 2014
    Maryland
    the easiest way to find an exhaust leak is seafoam through the vacuum line and look to see where the smoke comes out. hey it might be a clogged cat , but to have a significant decrease in fuel mileage without the car running noticeably different at the same time just seems odd. have you ever changed the O2 SENSORS ? remember the sensors got fogged with the same crap the cat did.
  10. #10 Re: New DP Opinions Please
    if it was clogged up it would feel gutless and feel like it lost 50 to 100 hp.
    they kinda sound like a vacuum with a full bag when on the gas hard. trying to suck, but cant. like when you put your hand over the suction tube.
  11. #11 Re: New DP Opinions Please
    Dec 2014
    Maryland
    zzp even warns that the high flow cat can throw a code. but that wouldn't make you lose fuel mileage. clear the codes again and unplug the battery like scotty says.
  12. #12 Re: New DP Opinions Please
    Newnan, GA
    I have not changed the o2 sensors. They appear to be working but they are old. Thinking I may change them because of murphys law at this point.
  13. #13 Re: New DP Opinions Please
    Newnan, GA
    So probably not clogged then. Still could be: exhaust leak, old o2 sensors, picky rear o2 sensor.
  14. #14 Re: New DP Opinions Please
    Quote Originally Posted by EHB View Post
    my car dont even know wtf a rear o2 is any more. i got a up stream o2 in the bung to just seal the hole, the wire is tucked up in the heat shield to fake out inspection lol. cat code is also deleted. but even catless it passed the cat test and went "ready" its only deleted now because i can delete it. i got a hi flow cat now cause NJ wants to see a cat.
  15. #15 Re: New DP Opinions Please
    Dec 2014
    Maryland
    a front O2 not throwing a code yet can still cause you to get bad fuel mileage. replace both of them and ONLY use acdelco's. amazon has them pretty cheap. about $30-35 each. do that first...100,000 miles they should be replaced anyway. i'd also change the plugs if you haven't done that since you had problems...they to were fogged. and clean your maf while your at it...lol
  16. #16 Re: New DP Opinions Please
    Newnan, GA
    Acdelco and not Bosch?
  17. #17 Re: New DP Opinions Please
    get delco o2's for sure.
  18. #18 Re: New DP Opinions Please
    Dec 2014
    Maryland
    Quote Originally Posted by EJOUIE View Post
    NO BOSCH !!! only ac delco...lots of people have problems with bosch.
  19. #19 Re: New DP Opinions Please
    Newnan, GA
    Done. Came to just about what my father owed me so only a little out of my pocket. If these don't fix the issue, I'm fairly certain they would fix another down the road. Car has 162,000 on it and to my knowledge the o2 sensors are stock.
  20. #20 Re: New DP Opinions Please
    Dec 2014
    Maryland
  1. Looking for opinions on what mod to do next
    By GTPguy87 in forum Introductions/Noob Questions
    Last Post: 06-27-2012, 11:05 AM
  2. Opinions on this?
    By mdwstgt in forum Off Topic Discussion
    Last Post: 06-17-2012, 04:09 PM
  3. need opinions..
    By Dragonblaze in forum Off Topic Discussion
    Last Post: 11-04-2010, 01:40 AM
  4. opinions
    By gtpinsc in forum Off Topic Discussion
    Last Post: 12-12-2009, 10:14 PM
  5. Mod Opinions
    By Amb4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-30-2009, 06:36 PM
