Thread: car starts in cold then shuts off unless I immediately apply gas.
Results 1 to 7 of 7
  1. #1 car starts in cold then shuts off unless I immediately apply gas.
    Dec 2013
    Niagara Falls Ontario
    well like the title says the car starts at warm temp no problem, but when very cold last winter the car would start for about 2 secs and then shut off unless I applied the gas as soon as it starts. I'm hoping to fix this before it gets to cold again as I'm worried maybe that the applying the gas trick might not work forever, but I'm pretty new to this diagnosing and fixing my own car stuff, so any help would be appreciated. Thanks a lot.
  2. #2 Re: car starts in cold then shuts off unless I immediately apply gas.
    And you drive a what??
    But anything tune up related always comes to mind. New plugs/wires, clean the throttle body and MAF sensor with their correct cleaners. Perhaps if you have a L36 motor, the fuel pressure regulator becomes weak in the cold and it could die right away.
  3. #3 Re: car starts in cold then shuts off unless I immediately apply gas.
    Dec 2013
    2006 grand prix 3.8 liter base model
  4. #4 Re: car starts in cold then shuts off unless I immediately apply gas.
    Sep 2012
    San Antonio
    Check your throttle body, it most likely is your culprit. I have a 2004 that was stalling like yours. You have to use "Throttle Body Cleaner". Better safe than sorry, and its not too expensive. Easy job too.
  5. #5 Re: car starts in cold then shuts off unless I immediately apply gas.
    Dec 2013
    I was just looking online and some people were saying that when finished cleaning a throttle body sometimes the computer will be out of sync when the car is idling. What precautions should I take regarding that? Thanks.
  6. #6 Re: car starts in cold then shuts off unless I immediately apply gas.
    Northern IL
    Did a search my 08 Base us doing the same thing. Just did a tune up with new plugs and wires and did not fix the issue. Thinking it might be a dirty MAF. Where you able to fix your issue?
  7. #7 Re: car starts in cold then shuts off unless I immediately apply gas.
    SWPA
    I'd think a dirty throttle body would be a place to start for you.
  1. intermittently car starts and shuts right off
    By Dee23 in forum General Grand Prix Discussion
    Last Post: 08-01-2014, 07:19 PM
  2. 02 Starts and then Shuts Off?
    By KitRae in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-12-2013, 12:20 PM
  3. Car starts 3-4 seconds and shuts off. P0122 and P1122
    By Brooks in forum General Tech Discussion
    Last Post: 08-28-2012, 07:47 PM
  4. Starts and dies immediately
    By STS in forum General Tech Discussion
    Last Post: 02-13-2012, 03:23 AM
  5. Car starts then as its about to Idle, car shuts off
    By fasterthenu2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2009, 05:51 PM
