Thread: Bad gas mileage help
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 70
  1. #1 Bad gas mileage help
    Jan 2017
    Canada
    Ive been having an issue with the mpg on my 05 grand prix base. Ive done plugs, wires lucas upper cylinder cleaner, sea foam cleaner for fuel lines ect. Cleaned the maf new air filter. Tire pressure is good and ive been driving pretty light footed for the most part. Any ideas
  2. #2 Re: Bad gas mileage help
    May 2008
    Schuyler, NE
    Any cel's? How bad is bad?
  3. #3 Re: Bad gas mileage help
    Jan 2017
    Canada
    No codes ..and like quarter tank in two days from back and forth from work ...where as before one tank would last pretty much 2 weeks and id drive on the weekend.
  4. #4 Re: Bad gas mileage help
    May 2008
    Schuyler, NE
    You need to figure out what you are actually getting. That could be just a difference of how the fuel gauge reads or winter gas.
  5. #5 Re: Bad gas mileage help
    Jan 2017
    Canada
    Question ...should my short term fuel trim be + all the time 0 and up while my long term is always -...like -15all the way to 25- and never going above from what ive seen so far on my odb reader
  6. #6 Re: Bad gas mileage help
    May 2008
    Schuyler, NE
    It depends. But, I would look at your ltft. If it's 15-25 at cruise, you have some mechanical problems.
  7. #7 Re: Bad gas mileage help
    Jan 2017
    Canada
    In the neg or pos?
  8. #8 Re: Bad gas mileage help
    Jan 2017
    Canada
    I just replaced my thermostat. A 195 and on the reader it only shows it to reach 85 maybe my therm sensor? Is this related?
  9. #9 Re: Bad gas mileage help
    May 2008
    Schuyler, NE
    Either negative or positive that far out is bad.
    Are you sure your reading in Fahrenheit and not Celsius?
  10. #10 Re: Bad gas mileage help
    Jan 2017
    Canada
    In celsius. And with the values like that what would cause that? Probs a few different things
  11. #11 Re: Bad gas mileage help
    Jan 2017
    Canada
    Temp wise on the dash it only gets to the 2 notch after the quarter mark
  12. #12 Re: Bad gas mileage help
    May 2008
    Schuyler, NE
    85 Celsius is 185f. So you are not far off there.
    You could have a fuel issue or a sensor issue.
  13. #13 Re: Bad gas mileage help
    Jan 2017
    Canada
    K well dont have a fuel pressure gage just yet...maybe look into the upstream 02 due to the negitive values or? Its just sucka because i have no codes and different possibilitys to check..just some ranging for low to high in cost
  14. #14 Re: Bad gas mileage help
    May 2008
    Schuyler, NE
    An o2 would be a good guess, especially if it has 50k or more miles on it.
  15. #15 Re: Bad gas mileage help
    Jan 2017
    Canada
    Okay so before i start changing things out...my short term is pretty much staying positve and my long term is always negative like -15 to-25ish.....o2 or maf?
  16. #16 Re: Bad gas mileage help
    May 2008
    Schuyler, NE
    How many miles are on the o2?
  17. #17 Re: Bad gas mileage help
    Jan 2017
    Canada
    Ive never changed in since we have had it around 07 08...yikes probs that? 170xxx on the od
  18. #18 Re: Bad gas mileage help
    May 2008
    Schuyler, NE
    Put a new one in and just clean the maf.
  19. #19 Re: Bad gas mileage help
    Jan 2017
    Canada
    Hey so after picking the o2 sensor up whats the socket size do i use
  20. #20 Re: Bad gas mileage help
    SE Level Member Billycar11's Avatar
    Apr 2015
    Pa
  1. Gas mileage...
    By mick777wauchope in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2012, 07:35 PM
  2. gas mileage ???
    By v8teezr in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2011, 07:13 PM
  3. Why am I getting bad Gas Mileage?
    By JDCMoney in forum General Tech Discussion
    Last Post: 06-10-2010, 01:34 PM
  4. bad gas mileage
    By Joe m in forum General Tech Discussion
    Last Post: 02-03-2010, 02:17 PM
  5. Better mileage on an old V8 than a GTP LoL!
    By Juanmiguel in forum The Rant Forum
    Last Post: 01-28-2010, 09:26 PM
