Thread: lim help
Results 1 to 4 of 4
  1. #1 lim help
    SE Level Member 08 gp lvr's Avatar
    Nov 2011
    north bay, ontario
    Im doing intake gaskets right now and im at the point were I need to remove the lim. All 12 bolts are removed and after lotssss of posts, I cant seem to find a diagram at all. Heres my problem. Im trying to pull up on lim and its not moving at all. Do I need to remove my tensioner or the front left dogbone? Awaiting anyones input. Cant afford to buy a new one if I break it. Thanks gang
  2. #2 Re: lim help
    Nov 2011
    north bay, ontario
    08 gp, and there was lots of oil in the lim. Didnt think oil went thru there. Hoping someone up this early lol
  3. #3 Re: lim help
    St. Louis
    Did you get the bolts in the coners? They are usually covered in oil. Should be one upfront right corner, and back left rear corner if you are standing in front of the car. Soak up the oil out of the LIM and see if they don't show up.
  4. #4 Re: lim help
    St. Louis
    If that doesn't help, try this thread. It's a common thing to do on these motors and there are tons of write-ups on it--> http://www.grandprixforums.net/threa...-and-questions
