Thread: Vacuum diagrams from top swapped car
Results 1 to 20 of 28
  1. #1 Vacuum diagrams from top swapped car
    Dec 2008
    Roxbury NJ
    Anyone got the diagrams for a top swap? Are they different from a normal GTP? Im assuming yes.
  2. #2 Re: Vacuum diagrams from top swapped car
    Barksdale AFB, LA
    If you did a full top swap, they'd be the same as an supercharged 3800 series II.
    2009 Subaru Impreza WRX STI
  3. #3 Re: Vacuum diagrams from top swapped car
    Dec 2008
    Roxbury NJ
    what do you mean by full? by full you mean all sensors and electrical?
  4. #4 Re: Vacuum diagrams from top swapped car
    GTP Level Member Scimmia's Avatar
    QCA, IA
    I think he means vs the SS M90 kit.
    2001 Buick Regal LS - Almost Stock
  5. #5 Re: Vacuum diagrams from top swapped car
    Barksdale AFB, LA
    By full, I mean everything. Not trying to reuse anything from your old L36 except the block.
  6. #6 Re: Vacuum diagrams from top swapped car
    Hoffman/Schaumburg, IL
    If you did a Full:
    Its very simple, Nipple under the supercharger snout goes to the MAP sensor, nipple on the BBV solenoid(the one pointing towards the Pass side of the car) and the L67 Fuel pressure Regulator,(the L36 regulator doesn't work with the boost, so you should be using the L67 rail and regulator)
    The One on the throttle body goes to the EVAP Solenoid.
    The Tree on the top of the supercharger:
    Big one pointing towards firewall goes to the brake booster.
    Middle one goes to the AC ducting control (the vac line that original connected dead center on the back of the L36 intake manifold)
    The front of the three connectors goes to the top of the BBV's diaphram(black cylinder of the BBV)
    That should be everything...... Not bad from the top of my head huh
  7. #7 Re: Vacuum diagrams from top swapped car
    Barksdale AFB, LA
    Quote Originally Posted by 02BlueGT View Post
    Good for me to know. I'll need to cap that since my HVAC is electronic and not vacuum operated.
  8. #8 Re: Vacuum diagrams from top swapped car
    Quote Originally Posted by Sabrewings View Post
    So what is there on the back of your L36's intake manifold....... Which Impalas don't have vacuum operated HVAC doors?
  9. #9 Re: Vacuum diagrams from top swapped car
    Barksdale AFB, LA
    Not sure. Is what you're talking about in this picture? That little cap on top of the brake booster line fitting?
    04+. 00-03 have vacuum operated systems. 04+ all use electronic doors.
  10. #10 Re: Vacuum diagrams from top swapped car
    Yes it is the little capped off part, you could probably use that cap on the vacuum tree, thanks for answering my question
  11. #11 Re: Vacuum diagrams from top swapped car
    Barksdale AFB, LA
    And thus answering my own, of where to get the cap.
  12. #12 Re: Vacuum diagrams from top swapped car
    Dec 2008
    Roxbury NJ
    oh wow, a lot easier than I thought. I dont think my monte carlo has that vac line, I didnt see it on mine when I started.
  13. #13 Re: Vacuum diagrams from top swapped car
    you dont need to hook up the BBV to a vac source on the bottom end. with the GT pcm you wont be able to control the BBV anyway, so just leave the bottom nipple open and end your vacuum line at the FPR.
    it goes MAP > LIM > FPR. youll get full boost with the BBV unhooked. if you hook it up like youre "supposed to" then boost will be limited to 4-5 psi.
  14. #14 Re: Vacuum diagrams from top swapped car
    QCA, IA
    If you don't hook it up at all, it will always be seeing atmospheric pressure, which also isn't a good thing, is it?
  15. #15 Re: Vacuum diagrams from top swapped car
    Barksdale AFB, LA
    If you load a L67 file onto the PCM and get the wiring added on, the BBV solenoid will work.
  16. #16 Re: Vacuum diagrams from top swapped car
    QCA, IA
    There should be a way to make it work without the solenoid at all, BBVs were used for a long time before cars were computer controlled. The solenoid is just there so the computer can dump boost if it wants to.
  17. #17 Re: Vacuum diagrams from top swapped car
    Barksdale AFB, LA
    Oh I'm sure. Just saying that if someone really wants it there, all it takes is software and a little wiring.
  18. #18 Re: Vacuum diagrams from top swapped car
    Dec 2008
    Roxbury NJ
    well Im not sure how ZZP tuned it if I need to hook the wire up or what, Im assuming they put those tables in. But Im not sure. Ill give them a call tomorrow and see whats up
  19. #19 Re: Vacuum diagrams from top swapped car
    Barksdale AFB, LA
    Anyone got a picture of the MAP end of the vacuum line, as it's on the engine? I guess, I'm asking for a shot looking down over the blower onto the MAP sensor.
  20. #20 Re: Vacuum diagrams from top swapped car
    I know you cant see the vac line(cause I was still running a L36 bin and map, you can see it off to the right), but that is where the MAP mounts, and the line just goes from under the snout to the bottom of the map.....
    BBV,
    If you load in a L67 Bin, you get the boost gauge in the DIC, and you can wire up the BBV solenoid.....
    You don't need to though, you can remove the solenoid, and have the top part of the diaphragm (black cylinder) connected to the vac tree on the top of the supercharger, and leave the bottom part open to atmosphere, this is how my car runs, and another local with a swap runs as well.....
    I am very glad that I'm able to answer your guys questions
    Note: you can see the BBV without the valve, and only the vac line in above picture
  1. Wiring Diagrams and Pinouts available for download here
    By Sinister Performance in forum PCM Tuning
    Last Post: 06-23-2015, 10:30 AM
  2. access to off toppic wiring diagrams
    By Toasty in forum General Tech Discussion
    Last Post: 02-06-2008, 11:15 PM
  3. 2004+ wiring diagrams
    Last Post: 01-14-2008, 01:15 PM
  4. L67 Swapped
    By 99LuminaLSC in forum Chevrolet Lumina
    Last Post: 12-15-2007, 08:57 AM
