Thread: Stock 0-60 times?
Results 1 to 20 of 24
  1. #1 Stock 0-60 times?
    GXP Level Member suitercrew's Avatar
    Oct 2015
    I'm trying to find the 0-60 time for a stock 99 GP GT Coupe but I can't find it anywhere or its a bogus answer like 6.0
    Sent from my LG-D851 using Tapatalk
  2. #2 Re: Stock 0-60 times?
    Banned
    Oct 2015
    Virginia
    GM claims 7.5 - 7.8 on Wbodies with the 3800
  3. #3 Re: Stock 0-60 times?
    Oct 2015
    Darn I thought my 8.3 was pretty good :/
  4. #4 Re: Stock 0-60 times?
    Banned
    Oct 2015
    Virginia
    In a perfect world I may add. The torque these engines make spin tires easily from a dead stop so its hard to tell.
  5. #5 Re: Stock 0-60 times?
    Banned
    Oct 2015
    Virginia
    Back before I knew any better I blew both front wheel bearings from spinning tires to get my jollies. Bad for the clutches and fluid in the trans too.
  6. #6 Re: Stock 0-60 times?
    Oct 2015
    True it was my first real run with the car too but I feel I controlled the spin fairly well.
  7. #7 Re: Stock 0-60 times?
    Oct 2015
    Haha ya I know what you mean, I wonder how much faster the car was 16 years ago and if its lost a lot of power from age.
  8. #8 Re: Stock 0-60 times?
    Banned
    Oct 2015
    Virginia
    Doubt its lost all that much unless you're burning oil like mad. A tune up never hurt. Its ok to light em up every once in a while, you'll get a better 0-60. If mine caught immediately Id probably be looking at 7.2-7.5 down from GM's 8.3.
  9. #9 Re: Stock 0-60 times?
    Banned
    Oct 2015
    Virginia
    One other thing to keep in mind is don't shift into fourth at WOT, the older 4T65e's were stripping splines off the 4th gear shaft and in some cases damaging the shaft itself.
  10. #10 Re: Stock 0-60 times?
    Oct 2015
    So gm said it was 8.3 ? What's better to launch with trac on or off?
  11. #11 Re: Stock 0-60 times?
    Banned
    Oct 2015
    Virginia
    Traction off. You'll spin a bit more but TC won't apply the brakes or retard timing to reduce wheel spin.
  12. #12 Re: Stock 0-60 times?
    Buffalo
    Quote Originally Posted by TemplesofLamneth View Post
    How are you still allowed to post?
  13. #13 Re: Stock 0-60 times?
    Buffalo
    16.5 1/4
    but who's driving and where and when?
    so unless you're comparing time slips , it's a moot point to say someone is slower then you
  14. #14 Re: Stock 0-60 times?
    Banned
    Oct 2015
    Virginia
    TC either applies brakes or delays spark timing to reduce power to cut back on wheelspin. Different systems in different vehicles, not sure exactly which one the 3800/W-body uses. There's others out there but thee principal is the same, ABS module briefly applies brakes upon the WSS detecting slippage or sends a signal to the PCM to reduce engine power long enough to regain traction.
    How have you not used your own advice and stuff an immeasurable amount of dicks in your ass?
  15. #15 Re: Stock 0-60 times?
    Buffalo
    Okay Mr Google , go ahead copy and paste , but it won't teach you how to understand this platform. The proof was watching you fail with an intake gasket..
    lots of "real" knowledge here but go on , continue to tell us how awesome you are. Please englihten us.
  16. #16 Re: Stock 0-60 times?
    Banned
    Oct 2015
    Virginia
    Not google, Automotive Technology a systems approach volume 5. It only listed a couple of ways traction is regained and unfortunately the attitude of the instructors is that well learn anything they don't teach us on the job. Not 100% sure the intake gasket has failed so put a hold on your dicksuckers until I change my oil here in another 300 miles. Not seeing a milk shake so I'm not too terribly worried about it at this point.
  17. #17 Re: Stock 0-60 times?
    man im i glad this tool is gone lol
  18. #18 Re: Stock 0-60 times?
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    Quote Originally Posted by suitercrew View Post
    the monte carlo (same car) with the 3.8 is 8.2 stock don't worry its normal
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  19. #19 Re: Stock 0-60 times?
    GXP Level Member
    Mar 2015
    Tomball
    Damn what did I miss? I did a first ever 0-60 last night and got 7.442 according to Torque pro, for whatever that is worth.
    Jeff
  20. #20 Re: Stock 0-60 times?
    May 2012
    Where winter never ends
    slow as balls :P
    2000 Regal - Winter Beater
  1. stock times?
    By buschegt in forum Introductions/Noob Questions
    Last Post: 03-19-2015, 11:29 AM
  2. Stock track times?
    By Seachicken in forum 5.3L V8 (LS4)
    Last Post: 05-08-2014, 12:22 PM
  3. Track times? Stock
    By mudneck4 in forum 5.3L V8 (LS4)
    Last Post: 05-06-2013, 01:00 AM
  4. 97-03 GT-Stock; 0-60 Times?
    By 01PonGPGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-20-2011, 09:53 PM
  5. Stock Shift Times?
    By 04CompG in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-02-2009, 03:11 PM
