Thread: Troubleshooting help. Engine won"t start
Results 1 to 7 of 7
  1. #1 Troubleshooting help. Engine won"t start
    SE Level Member jimcarey78's Avatar
    Oct 2008
    londonderry, nh
    I have a 96 Gtp 3.4 liter engine with issues. I have an engine that will not start. I have replaced the spark plugs, wires, ignition coils. Here is where it all began I just replaced my fuel tank and it ran fine. Now my engine oil smells like fuel and the cylinders are flooded with gas. I have fuel and spark but no combustion. Any tips??
  2. #2 Re: Troubleshooting help. Engine won"t start
    Oklahoma
    If you are getting that much fuel in your oil, it could be a leaky injector or one that is staying open, possibly a fuel pressure regulator. At least that is where I would start.
  3. #3 Re: Troubleshooting help. Engine won"t start
    Feb 2008
    Quote Originally Posted by jimcarey78 View Post
    Fuel odor is probably coming from the fuel that is being injected into the cylinders that is not being burned, so it seeps down past the rings and into the oil. You say you have spark, how did you check that?
  4. #4 Re: Troubleshooting help. Engine won"t start
    Oct 2008
    londonderry, nh
    Hello,
    Sorry for the late response. I starting working on the car agin and this is what I have. I have spark at all 6 plugs (tested with a spark plug and clamp to ground) I have new wires, new coil packs, but no combustion. I can see the unburned gas on the cylinders. I have 45 PSI at the gas manifold. I have noticed some oil on the spark plug wires and a milky white substance outside of the engine. Any ideas on what will cause the engine not to fire? The only thing I have not checked is combustion.
  5. #5 Re: Troubleshooting help. Engine won"t start
    Sep 2011
    Minnesota
    I agree with the fuel reg. thing ,you are getting to much fuel in the cylinders, plugs are most likley fouled
  6. #6 Re: Troubleshooting help. Engine won"t start
    If you just did the pump. did you kick the key on/off a ton of times w/o starting it? I've seen cars get horribly flooded by this, which can allow some into the oil.
  7. #7 Re: Troubleshooting help. Engine won"t start
    Florida
    -have you tried a compression test? i had fuel and spark but turned out timing jumped and i had only 30psi of compression!
    -first things to try is to clean out the cylinders. pull the fuel injector relay and fuse. then pull all the spark plugs and turn over the engine. this will give you a chance to do a compression check too.
    if compression is good put plugs back in and try and start it. 45psi is correct pressure so that is good.
  1. General Starting and Engine Troubleshooting Guide [*]
    By TyroElite in forum How To Write-Ups/Tech Tips
    Last Post: 12-15-2010, 12:24 PM
  2. 3.5" tuned PCM running on 3.8" engine
    By 04CompG in forum PCM Tuning
    Last Post: 10-06-2008, 05:14 PM
  3. My "second" GP and third 3800 engine!
    By Deezul_AwT in forum Introductions/Noob Questions
    Last Post: 02-23-2008, 01:04 PM
  4. engine will start only if
    By ryangtp89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2008, 07:34 PM
