Thread: 3.4 stock performance mods
Results 1 to 9 of 9
  1. #1 3.4 stock performance mods
    Dec 2012
    Ft. Lupton Co
    Hey guys if have a 94 Gtp. I was wondering if there was any stock mods
    to add to my car
  2. #2 Re: 3.4 stock performance mods
    Nov 2010
    Ray MI
    Stock mods?
    One thing to do is get the 1996 3.4 upper intakes and such and swap those on. It's good for some HP. The removable throttle body on the 96+ engines gives you more options to change out your TB to a bigger one.
    1991 Grand prix GT
    1994 Cutlass Supreme
    2000 Grand prix GTP
  3. #3 Re: 3.4 stock performance mods
    new britain, ct
    well you could get a cone filter as well as a downpipe.
    07 Black GXP.
  4. #4 Re: 3.4 stock performance mods
    Dec 2012
    Ft. Lupton Co
    Quote Originally Posted by ctracer View Post
    What do u mean as a down pipe.
  5. #5 Re: 3.4 stock performance mods
    new britain, ct
    you could get a bigger downpipe from your exhaust manifolds to your cat converter so it flows a little better.
    07 Black GXP.
  6. #6 Re: 3.4 stock performance mods
    Dec 2012
    Ft. Lupton Co
    Is there any newer Pontiac that could get it off of or will it b a after market part.
  7. #7 Re: 3.4 stock performance mods
    new britain, ct
    aftermarket.
    07 Black GXP.
  8. #8 Re: 3.4 stock performance mods
    Dec 2012
    Ft. Lupton Co
    aftermarket.
    Ride on thank you. I'll have to check that downpipe out.
  9. #9 Re: 3.4 stock performance mods
    GT Level Member 91gpse's Avatar
    warren, mi
    i agree with the removable throttle body... you see alot of them on oldsmobiles and monte carlos i have one myself and theres some 5 or 6 throttle bodys you can choose from aftermarket. also something thats relatively cheap is the u bend delete. you cut off the bend in the end of your exhaust and run two pipes from in front of your fuel tank one on either side and then run your two mufflers out. you can also remove your resinator if you havent already gives you a nice sound. alot of people use flowmasters because their cheap but i have borlas on the back of mine. and if your looking into down pipes i would suggest zzp. if you want to get into the motor a bit... you can port and polish the heads. or even headers arent too bad nowadays.
  1. Doing another LIM job... what performance mods while I am in there?
    By Elite6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-28-2012, 07:35 PM
  2. Performance Mods
    By kking89 in forum General Tech Discussion
    Last Post: 08-30-2011, 10:04 AM
  3. Performance mods?
    By Shaunathin94 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-09-2011, 09:17 AM
  4. New 98 GTX and I need some advice for performance mods! : )
    By GTX98 in forum Introductions/Noob Questions
    Last Post: 06-14-2010, 02:40 AM
  5. mods and performance?
    By zewski2469 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-30-2009, 05:59 AM
