Thread: 3.4 DOHC Torque Curve
Results 1 to 10 of 10
  1. #1 3.4 DOHC Torque Curve
    Bettendorf, IA
    Anyone have information on Torque curve on these engines? I'm looking at changing gear ratios, i want to make sure I try to optimize torque/hp so I don't under gear (poor performance) or over Gear it(worse gas mileage)
  2. #2 Re: 3.4 DOHC Torque Curve
    How are you going to tune it for those changes?
    A good guess would say your powerband is 2500-5000ish rpm an faills off before it shifts. You should just leave it.
  3. #3 Re: 3.4 DOHC Torque Curve
    GT Level Member 91gpse's Avatar
    warren, mi
    i would agree with five finger death punch... if you want to mess with gears your better off getting a manual trans. which its not worth it unless you got some serious mods in the engine.
  4. #4 Re: 3.4 DOHC Torque Curve
    new britain, ct
    since this thread got bumped....these 3.4 dohc engines make good use of the upper powerband.
    a guy on here had 3.69's? i think? and he absolutely loved them with this engine.
    07 Black GXP.
  5. #5 Re: 3.4 DOHC Torque Curve
    Bettendorf, IA
    3.69? Came with factory 3:43. Wonder how he got to 3:69?
  6. #6 Re: 3.4 DOHC Torque Curve
    Dec 2013
    laporte mn
    U get 3.69 by using a final drive from a 3100 v6 car with a 4t60e. And he also used a 245/45r17 tire and ended up with a ratio of 3.73. The guy I know that has done it is z34phoenix. He is on wbody forum a lot. I also have done the diff swap to 3.69 but my car isn't driving until the snow clears so I don't have any opinion on it
    Sent from my MB886 using Tapatalk
  7. #7 Re: 3.4 DOHC Torque Curve
    Florida
    no actually when you install the 3100 final drive you end up with 3.73's using my 245/45-17 tires the final drive would be equivalent to 4.09
  8. #8 Re: 3.4 DOHC Torque Curve
    SE Level Member padgett's Avatar
    Feb 2016
    Orlando
    My SPI includes FV0 RATIO, TRANSAXLE FINAL DRIVE 3.67
  9. #9 Re: 3.4 DOHC Torque Curve
    Bettendorf, IA
    3:69? Wow, and I thought I loved the 3:43. Reprogramissues?
  10. #10 Re: 3.4 DOHC Torque Curve
    Florida
    Just used a DHP power tuner and then remapped the shift points. Needed a special release of the dhp software. The latest release doesn't have the settings needed for the 96 z34
  1. 3.4 dohc
    By 67GTO in forum General Tech Discussion
    Last Post: 06-11-2010, 06:36 AM
  2. Engine swap - 96' 3.4l DOHC out, '93 3.4l DOHC
    By csbrown in forum 3.4L V6 (LQ1) DOHC
    Last Post: 11-11-2009, 04:47 PM
  3. Replies: 12
    Last Post: 02-08-2009, 01:06 AM
