Thread: Keep my Resonator or not
Results 1 to 11 of 11
  1. #1 Keep my Resonator or not
    SE Level Member rij1's Avatar
    Nov 2011
    Ventura, Ca
    My resonator is making noise like metal chattering and dont know if I should replace it with another one or a glass pack or just remove it and weld a pipe in it's place. I have two dynomax super turbo mufflers on it already.
    94 Grand Prix GTP Coupe 3.4L 24v V6, DynoMax Super Turbo Mufflers
  2. #2 Re: Keep my Resonator or not
    GET A GLASSPACK
    zomg.
    Please.
    Like $30 at your local auto parts store.
  3. #3 Re: Keep my Resonator or not
    Out West
    Get rid of it.
  4. #4 Re: Keep my Resonator or not
    blue, its a 60*, it'll be okay.
  5. #5 Re: Keep my Resonator or not
    Willoughby, Ohio
    with no ressy it wont sound bad just drone on the highway sooo its all in preference
  6. #6 Re: Keep my Resonator or not
    It's still a V6, needs more resonation lovin
  7. #7 Re: Keep my Resonator or not
    Florida
    nawwww my exhaust on the DOHC is the same im running now. both sound great. 2.5" high flow cat, 2.5" x 18" magnaflow muffler, 18" glass pack and dual tips.
    which resonator are we talking about. the one under the car or IIRC there is one on the passanger side
  8. #8 Re: Keep my Resonator or not
    Nov 2011
    Ventura, Ca
    The one under the rear passanger side
  9. #9 Re: Keep my Resonator or not
    SE Level Member pontiacgtp24's Avatar
    Jan 2012
    Michigan
    Im also wondering about my resinator and weather or not i should be going to something different.no cat on the car still has all other stock piping except for two 4' supertrapps running 8 discs now.Im going to try 12 plates each side as it still feels a little trapped at higher rpms.i would just like to make the note a little deeper without sacrificing to much power.
  10. #10 Re: Keep my Resonator or not
    get rid if you want, wont drone as much as the 3800's
    so you'll be fine without one
    SMGPFC Member #10
  11. #11 Re: Keep my Resonator or not
    SE Level Member greenmachinegtp's Avatar
    Crossville, TN
    make sure that you tell the installer you dont want a b.s. patch and if they use any pieces to put it together that you dont want them to use smaller diameter pipe than whats on there already.
  1. resonator
    By krippled in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-19-2011, 12:18 PM
  2. Resonator cut...
    By SlowM90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-25-2010, 02:11 AM
  3. Resonator
    By chitownchevy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-03-2008, 09:38 AM
