Thread: 1992 Richard Petty Edition Grand Prix Starts the dies
Results 1 to 5 of 5
  1. #1 1992 Richard Petty Edition Grand Prix Starts the dies
    Aug 2011
    Florida
    New to this Forum and Grand Prix's. I just recently bought a 1992 Richard Petty Edition Grand Prix. It starts then quickly then dies, it will stay running as long as I keep my foot on the gas but won't rev past 3000 rpm's. The previous owner said it had sat for some time due to a cracked lower intake manifold.
    I replaced the lower intake, drained the fuel, replaced all the fluids & filters. Is there some thing I may have missed or from sitting so long is there something else I need to replace or clean, bad sensor or something else. Any help will be greatly appreciated.
    Thanks in advance for any assistance, David
  2. #2 Re: 1992 Richard Petty Edition Grand Prix Starts the dies
    Waukesha, WI
    maf sensor, crank position sensor maybe? fuel filter?
    ps sell me your wheels
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  3. #3 Re: 1992 Richard Petty Edition Grand Prix Starts the dies
    Aug 2011
    Florida
    Quote Originally Posted by redlinepontiac View Post
    Thank you for the info Redline Pontiac, I will try and replace those sensors, already replace the fuel filter.
    Thanks again, David
    PS- I will keep you in mind if I decide to sell the wheels.
  4. #4 Re: 1992 Richard Petty Edition Grand Prix Starts the dies
    Donating Users RareGMFan's Avatar
    Dec 2008
    Naperville, IL
    How many miles, and has the timing belt ever been changed?
    PREVIOUS: '89 Pontiac 6000 STE AWD (2/1376), '90 Pontiac GP SE McLaren Turbo (1/2749)
    '90 Pontiac Grand Prix STE McLaren Turbo (1/1000), '01 Pontiac GP GTP Special Edition (1/1341)
    CURRENT: '00 Pontiac Grand Prix GTP (ugh...boring regular one)
  5. #5 Re: 1992 Richard Petty Edition Grand Prix Starts the dies
    Florida
    have you tested fuel pressure. mine just started doing that the other day and when i tested fuel pressure it was less then 1/2 of what it should be. should test 41-55 key on engine off and 44-58 engine on. it was reading 31 key on engine off and engine on was 18psi. i have a P0171 for bank 1 lean. so its not like there is a stuck open injector.
    if fuel pressure is good then i would look at: MAF make sure it is clean. TPS. VAC leaks.... these engines can be very tricky to get back together without vac leaks.
    the good thing is they are bullet proof. i have 220k miles on mine and the engine is still running strong. just the tranys that cant hold up.
  1. Richard Petty grand Prix for sale
    By PNIGZ in forum Off Topic Discussion
    Last Post: 03-06-2010, 10:16 AM
  2. 1991 grand prix starts then dies after five minutes
    By oithebusiness in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-15-2009, 12:54 AM
  3. 1999 Richard Petty Concept Grand Prix
    By 2000GTP in forum Off Topic Discussion
    Last Post: 07-25-2009, 11:38 PM
  4. 90 Grand Prix starts, then dies
    By Fishhead5 in forum General Tech Discussion
    Last Post: 06-05-2009, 10:35 AM
