Thread: Gasket/Leaking problem
Results 1 to 12 of 12
  1. #1 Gasket/Leaking problem
    SE Level Member Phil_GTP's Avatar
    Hagerstown
    within the past 2 months i have dumped 1500 into my 3.4l DOCH just in gaskets!!!!! Intake manifold head gaskets, and valve cover gaskets. and im still having problems with leaking anti-freeze. any suggestions???
    Oklahoma
    Im assuming that the coolant is not leaking externally?
    I live here. UR LOSN's Avatar
    Rockford, IL
    do you know if the exhaust smells like coolant? try doing a compression check on it....also. they make a UV kit for coolant leaks. you add it to your cooling system..and they supply you with the light and glasses..
    after a few cycles of driving. you can come back and use the light/glasses..and visually check for exterior leaking..just to rule it out.
    if it is internal....possibly head gasket. it is a very common thing with the 3.4 DOHC. more than likely it is the rear head as well. you have done nothing wrong.....it happens with age.
    Hagerstown
    Quote Originally Posted by UR LOSN View Post
    thanks! yea its def external, ive had both the intake, and head gaskets replaced. so yea. any idea where i can buy one of these kits??
    Rockford, IL
    Napa, O'Reilly, Autozone, Advanced auto....any parts store pretty much.
    GTX Level Member MTXGTP's Avatar
    wamego,KS
    i hate those intake manifold gaskets just my 2 cents. o did you have them replace the oils pump shaft seal?
    Justin Young, Kansas
    1999 silver GTP DHP pcm,3" Cattless hogan DP,Front PLOG,3.4 pulley, ported TB, ported LIM, ported supercharger housing.porting done by GBP
    coming soon: LS6 springs ,1.9rr
    Hagerstown
    Quote Originally Posted by MTXGTP View Post
    no i didnt?? is that something i should ask them about
    wamego,KS
    well i did an intake manifold gasket on a friends car and not even two weeks later that seal went out if you look under the throttle body almost where the tranny and engine meet you will see this cap there and there is a seal there that should be replaced while the intake plenum just to save you from having to have it done again the shaft is like a foot long so in order to get it out you must take the upper plenum off.
    GTP Level Member s1795so2's Avatar
    alhambra, Il
    Sorry for not really adding anything to this thread but you really need to just do a 3.8 sc swap ftw. Trannyman would probably be willing to help you out.
    Steven Oliver
    2004 GTP comp-g WS6. Gator and suede all around interior.
    Advanced MECP certified installer, custom upholsterer.
    <img src=http://i86.photobucket.com/albums/k87/s1795so2/random%20pics/manbike.jpg border=0 alt= />
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    have you inspected the water pump?
  11. #11 Re: Gasket/Leaking problem
    look for leaks, intake gaskets dont usually leak on the dohc.
    **Wanted: 94-97 3.4 Underdrive Pulley**
    Set of 97-03 Tinted Tails for Sale - STILL
  12. #12 Re: Gasket/Leaking problem
    SE Level Member Identity Crisis's Avatar
    Edmonton, Alberta Canada
    In order to change the Distributor shaft seal on the LQ1 you have to remove the rear cam carrier. It is not like the 3.1-3400s.
  1. i didnt see where i could put this problem?
    By NME in forum Off Topic Discussion
    Last Post: 12-29-2007, 02:10 AM
