Thread: Cold Idle Miss
Results 1 to 3 of 3
  1. #1 Cold Idle Miss
    IN
    I have a 1995 GTP with the 3400 DOHC 128000 miles on it. I just got the car it set for 2-3 years. I am finally getting all the bugs worked out of it. Replaced plugs wires coil packs and a faulty cam sensor. No more codes. I am getting a very definate miss at idle when i first start the car in the morning if the ambient temp is below 65 degrees. The scanner says cylinder 3 weak. I ran two treatments of fuel injector cleaner through it with no change. Once the car is warm it runs just as smooth as can be. Anybody got a suggestion?
  2. #2 Re: Cold Idle Miss
    IN
    Bump for today. Anybody got an idea?
  3. #3 Re: Cold Idle Miss
    IN
    In case anyone cares...I did intake manifold gaskets this past weekend and that seems to have fixed all my cars little problems. Thanks for all the help.
  1. I miss my LT1
    By Black18Ice in forum Off Topic Discussion
    Last Post: 10-01-2009, 11:07 PM
  2. miss??
    By streetsmart in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-18-2009, 01:15 PM
  3. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
  4. I miss my car!
    By JCG's-GTP in forum Visual/Body Modifications
    Last Post: 04-15-2009, 12:55 AM
  5. Wased my engine at the car wash 2 weeks ago, still have miss at idle.
    By PCweber in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-07-2009, 05:59 PM
