Thread: Rough Idle and Dimming Lights
Results 1 to 15 of 15
  1. #1 Rough Idle and Dimming Lights
    SE Level Member paulygp09's Avatar
    Minnesota
    I have a 95 GTP that will randomly run roughly especially at idle. When this happens all of the lights will dim and the gauges jump. At highway speeds it runs ok until I turn the headlights on then the gauges jump again and everything dims. I had a mechanic work on the car and he replaced the water pump, power steering, crankshaft sensor, and alternator so I know it's none of these. WHAT COULD IT BE?
    ~Pauly~
  2. #2 Re: Rough Idle and Dimming Lights
    Pennsylvania
    Quote Originally Posted by paulygp09 View Post
    Did you test your battery? (though, I still feel like it's a bum alternator)
  3. #3 Re: Rough Idle and Dimming Lights
    Minnesota
    new battery in feb and new starter also.
    ~Pauly~
  4. #4 Re: Rough Idle and Dimming Lights
    Pennsylvania
    Have any squirrels chew on your wiring harness?
  5. #5 Re: Rough Idle and Dimming Lights
    Minnesota
    no lol... i may have the battery and alternator checked just to be safe... maybe a bad ground somewhere could be the problem?
    ~Pauly~
  6. #6 Re: Rough Idle and Dimming Lights
    Pennsylvania
    Well, once it's running, the battery shouldn't factor in. So... alternator, plug wires plugs?
  7. #7 Re: Rough Idle and Dimming Lights
    Minnesota
    its wierd cuz sometimes it will start to turn over then stop about half a turn then when i try to turn it over again it will just click and it will do this 6-10 times before it will turn over again....
    ~Pauly~
  8. #8 Re: Rough Idle and Dimming Lights
    Pennsylvania
    O_o ummm... ground wires? Like... are they torn?
  9. #9 Re: Rough Idle and Dimming Lights
    Minnesota
    better just stick to driving the ol SE with the 3.1! problem solved lol
    ~Pauly~
  10. #10 Re: Rough Idle and Dimming Lights
    Minnesota
    ok... today i drove the car again and when i used the turn signal the car would either die or every light on the dash would come on as well as the dinger and the doors would lock and unlock... come on guys and gals, someone has to know!
    ~Pauly~
  11. #11 Re: Rough Idle and Dimming Lights
    Minnesota
    bump
    ~Pauly~
  12. #12 Re: Rough Idle and Dimming Lights
    I gunna say its the battery or the alternator going bad. GO to a o riellys or autozone and have them run battery and alternator test. The alternator test should be done with the car on and battery with the car off. Im guessing maybe a diode is going bad and causing things to pull power away from certain things. But i could be wrong. So I would run those tests to see whats up.
    or maybe one of the cables off of the battery conections is going bad too.
  13. #13 Re: Rough Idle and Dimming Lights
    Donating Users RareGMFan's Avatar
    Dec 2008
    Naperville, IL
    That's the first thing I thought of when he said sometimes it will just randomly stop cranking (indicate abrupt loss of electrical power) when trying to start the car, and then would crank again if you turned the key. That's a pretty good indication that you either have a loose battery cable, or ground. My Turbo STE did the same thing once. Would give weird symptoms, and then just randomly shut down on me one day just before I got home. Popped the hood and wiggled the cables, and noticed the positive was a bit loose. Tightened it down, and never had a problem after that.
    I almost always change the post bolts when I get a new batter, because they really weren't designed to be loosened and tightened several times. They only cost a few bucks to replace, which is nothing in exchange for the piece of mind they offer.
    PREVIOUS: '89 Pontiac 6000 STE AWD (2/1376), '90 Pontiac GP SE McLaren Turbo (1/2749)
    '90 Pontiac Grand Prix STE McLaren Turbo (1/1000), '01 Pontiac GP GTP Special Edition (1/1341)
    CURRENT: '00 Pontiac Grand Prix GTP (ugh...boring regular one)
  14. #14 Re: Rough Idle and Dimming Lights
    Minnesota
    had a GM specialist check it out, it was something to do with the security system... basically everytime i would start the car the security would try to cut power and kill the engine
    ~Pauly~
  15. #15 Re: Rough Idle and Dimming Lights
    Pennsylvania
    You can sleep easy at night knowing that a thief could only kinda drive your car.
  1. Lights and power issues / Dimming and slow
    By zeppelinrocks18 in forum Audio, Security & Visual Electronics
    Last Post: 05-07-2012, 04:04 AM
  2. rough idle
    By stanggreg90 in forum General Tech Discussion
    Last Post: 05-22-2010, 11:37 PM
  3. rough idle
    By 02gtpalder in forum General Tech Discussion
    Last Post: 03-07-2010, 12:02 AM
  4. rough idle 02 gtp
    Last Post: 03-06-2010, 01:16 PM
  5. Almost rough idle
    By DesQ27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-01-2009, 08:31 PM
