Thread: anyone with good knowledge of the 3400 DOHC?
Results 1 to 7 of 7
Reppusmic anyone with good knowledge of... 09-20-2009, 09:00 PM
mikedinthecity Re: anyone with good... 09-23-2009, 02:10 AM
PowerStroker Re: anyone with good... 09-24-2009, 03:37 AM
Duke1822 Re: anyone with good... 10-13-2009, 08:30 PM
FoSHO99 Re: anyone with good... 10-13-2009, 10:36 PM
16MustangVet Re: anyone with good... 10-26-2009, 12:42 AM
FoSHO99 Re: anyone with good... 10-26-2009, 05:00 PM
  1. #1 anyone with good knowledge of the 3400 DOHC?
    Buickville
    ok, im not going to mention the car im using this motor in, but i have a 3100 in my car at the moment and i was looking at doing a motor swap with this engine, instead of the 3800 supercharged( cant find a single one of these around me). does this engine have a supercharger available? if not what turbo would you reccomend to get the best power out of it? when i get the engine im replacing all of the crank and cam bearings and the piston rings since im getting it out of a junkyard car that was rear ended. is there anything else anyone can come up with besides intake and exaust to make a monster of an engine out of this?
  2. #2 Re: anyone with good knowledge of the 3400 DOHC?
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    i had one. never again. funny when they first designed these engines in like 91 they didnt have a trans strong enough to hold the engine. they cut power back so the trans would hold up. i know the valves are made of sumthing special and they are lightweight. i also kno this is a non interference engine. they have a great oiling system. also there is a timming belt. i dont like replacing the altenater on these its at the bottom in the rear on the pass side...... i have a supercharged 3800 now and i would not do anything with a dohc 3400 except a boat anchor. sorry my opinion.
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  3. #3 Re: anyone with good knowledge of the 3400 DOHC?
    SE Level Member PowerStroker's Avatar
    Minnesota, Eh?
    I have the 3100 in my car and it hasn't been the worst engine, but its got its faults. The 3400 with a 3400 transmission will hold up FINE if you're just looking for a high mileage everyday driver.
    My father just bought a 2005 Impala with the 3.4 and he told me he's never owned a smoother, more efficient engine. So the swap would work, just get a transmission to go with it.
    I've learned on these forums, if you don't have a 3.8, good luck...
    2003 F-350 7.3L Powerstroke, hybrid (burns diesel and rubber ), lots of mods, and gets 22.5 mpg!
    2000 Grand Prix SE 3.1L
  4. #4 Re: anyone with good knowledge of the 3400 DOHC?
    SE Level Member Duke1822's Avatar
    Toledo,OH
    like miked said bout the de tuning GM did i dont know how much time you want to put into getting the power back that they took away prob with restrictive exhaust,intake and PCM then going for mods to get it up to 3.8-SC power levels might take a wile but I would like to here about it if you do its something different for sure.
    02 GP GT 40,000 mi Stock For Now
    87 Firebrid Formula 65,000 mi
  5. #5 Re: anyone with good knowledge of the 3400 DOHC?
    Jan 1970
    Maquoketa, Iowa
    Were in the process of throwing a cammed 3800 S/C and hd tranny in a 1993 lumina. It can be done and is probably easier in the longrun to make the power levels you want.
  6. #6 Re: anyone with good knowledge of the 3400 DOHC?
    Cammed S/C 3800 in a lumina I gotta see pics of that monster. Now that would be a fun sleeper.
  7. #7 Re: anyone with good knowledge of the 3400 DOHC?
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by 02GrandPrixIraqVet View Post
    http://www.facebook.com/home.php?#/p...8&id=562935337
    http://www.facebook.com/home.php?#/p...0&id=562935337
  1. Wobble/shake at around 3400 rpm
    By vertebrate in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-23-2011, 08:47 AM
  2. My last hope ..... help for a 3400 engine
    By DWosik13 in forum Off Topic Discussion
    Last Post: 01-12-2009, 11:21 PM
  3. For My Knowledge Really...
    By blueguy in forum PCM Tuning
    Last Post: 09-12-2008, 12:15 AM
