Thread: exhaust inlet/outlet
Results 1 to 2 of 2
carman exhaust inlet/outlet 05-04-2009, 07:17 AM
carman Re: exhaust inlet/outlet 05-07-2009, 12:01 PM
  1. #1 exhaust inlet/outlet
    pennsylvania
    ok im hoping for a quick respose or else i may run into alot of problems this afternoon. '92 grand prix se 3.4L DOHC, i want to cut the stock mufflers off and replace them with some cheap ones just to pass inspection but im not sure the exhaust size. i cant find stock mufflers for it anywhere local so there for i cant find anyone to provide me with the size i need. i picked up two 2 1/2" mufflers because that was my best guess and i could always use reducers if they are the wrong size but i hate to go out this afternoon and cut my mufflers off and be stuck here until my girlfriend gets home because they dont fit. also i was told that i had a leak at the exhaust manifold and they werent sure if it was the gasket or a crack. i wanted to just replace the rear manifold but i cant find that anywhere either. anyone know any place i could find these parts, im located in johnstown PA and iv tried all the parts stores and salvage yard i could find within a 2 hour radius.
  2. #2 Re: exhaust inlet/outlet
    pennsylvania
    well no quick reply to that because its been 4 days but they are 2" if anyone is wondering and they are a pain to cut off. iv got the drivers side off and im half way throught the passenger side but i snapped a blade and i dont have any others so i have to wait till later to get a blade and exchange the 2 1/2" mufflers that i bought. I dont know what made me think that size im usually better at guessing than that. If you are also planning to attempt this i would suggest that you also find 2 pieces of exhaust pipe about 4-5 inches long to patch between the old exhaust and the new mufflers because sizing mine up i found that the mufflers are shorter than i would like and it dosent look good at all. Im planning to get dual tips to replace that stock look that i liked so much
  1. Exhaust inlet/outlet size...
    By black98gt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-23-2010, 01:57 PM
  2. pre outlet
    By 04GTP in forum Audio, Security & Visual Electronics
    Last Post: 11-18-2008, 12:09 PM
