Thread: 1996 gtp tail pipe smoke
Results 1 to 11 of 11
  1. #1 1996 gtp tail pipe smoke
    Mar 2017
    CNY
    Just picked up a 96 GTP to fix up. It smokes a little on start up. Light smoke that smells like gas. I was thinking valve seals? Any other ideas on where to start?
  2. #2 Re: 1996 gtp tail pipe smoke
    Color?
    Blue would be oil, white is coolant and the off grey color can be condensation and some fuel.
    If the cat converter is the factory one it's likely not helping to burn off some extra fuel on warm up.
  3. #3 Re: 1996 gtp tail pipe smoke
    Mar 2017
    CNY
    Its very light not sure if you can tell from the pic. It's not thick white maybe a little blue
    1996 gtp tail pipe smoke Attached Images
  4. #4 Re: 1996 gtp tail pipe smoke
    Seems like steam and maybe some unburnt fuel if you can smell it. Though like I said if the cat converter isn't doing it's job anymore you are going to smell the raw fuel smell of a catless exhaust.
  5. #5 Re: 1996 gtp tail pipe smoke
    Mar 2017
    CNY
    Okay. I got the video working to better see what I'm talking about
    https://youtu.be/SEY2AGXYzFQ
  6. #6 Re: 1996 gtp tail pipe smoke
    Dec 2012
    troll land
    Any fluids low? I'd make sure it wasn't just bad gas. Also have you changed lims yet?
  7. #7 Re: 1996 gtp tail pipe smoke
    Mar 2017
    CNY
    Oil is down a little bit. None of the gaskets have been changed. Previous owner said it was sitting a while so the gas probably is old. It's misfiring also. The smoke gets a little worse once it runs longer. I noticed it's not getting up to temp after I let it run
  8. #8 Re: 1996 gtp tail pipe smoke
    HUDSON
    Are you sure what you are seeing as "smoke" is not normal exhaust water vapor?
  9. #9 Re: 1996 gtp tail pipe smoke
    Mar 2017
    CNY
    Here's a better video after it ran a little longer. Looks like blue smoke
    https://youtu.be/hXuSaflNYw4
  10. #10 Re: 1996 gtp tail pipe smoke
    HUDSON
    You need to get the exhaust system and engine good and hot just to make sure that what you are seeing is not water vapor condensing on the cold pipes (perfectly normal).
  11. #11 Re: 1996 gtp tail pipe smoke
    May 2017
    Dirtyzville, Mizzery
    You'll smell oil, just like you'll smell coolant, or a toasted converter.
    1999 Chevrolet Silverado K1500 Classic Z71 - Intake/Gibson Exhaust/20% Tint
    2004 Chevrolet Corvette MRM A4 - C5Z Suspension/AFE S2 Intake/TSP Catless LT's/3" ORX/C6 ZR1 Wheels
    Sold WBody's: '98 GT, '98 GTP, '03 GTP, '05 GXP
  1. 1996 Grand Prix Tail Lights
    By paulygp09 in forum Visual/Body Modifications
    Last Post: 03-06-2010, 09:10 PM
  2. smoke out tail lights
    By mzendano in forum Visual/Body Modifications
    Last Post: 04-01-2009, 11:58 AM
  3. Smoke coming from driver side below crossover pipe
    By millfire517 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-26-2009, 05:17 PM
  4. Drooping tail pipe
    By Deezul_AwT in forum General Tech Discussion
    Last Post: 06-27-2008, 11:12 PM
