Thread: Driver side door wont open inside or outside what to do !?
Results 1 to 14 of 14
  1. #1 Driver side door wont open inside or outside what to do !?
    SE Level Member DanGrandPrix's Avatar
    Oct 2016
    Fresno CA
    I installed a new door handle to my Pontiac sine the old one would only opened on a good day.Now the door wont open from either side i have no idea what to do now anyone have any advice?
  2. #2 Re: Driver side door wont open inside or outside what to do !?
    Omaha, NE
    Which handle did you replace, interior or exterior?
  3. #3 Re: Driver side door wont open inside or outside what to do !?
    Oct 2016
    Fresno CA
    The exterior
  4. #4 Re: Driver side door wont open inside or outside what to do !?
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Is the door panel off?
    GPONA #1 Cyber Bully
  5. #5 Re: Driver side door wont open inside or outside what to do !?
    Oct 2016
    Fresno CA
    Nope but from what i remember even with it off i cant reach the mechanism.I did this a year ago when my clutch also needing repair i bought another car out of frustration.But i miss driving my 3.4 DOHC everyday.
  6. #6 Re: Driver side door wont open inside or outside what to do !?
    sounds like the linkage rods fell off maybe. the plastic clips wear out and break.
    best bet might be to take the pass side door panel off and see if you can with looking at it fish a rod to the main latch and open the door, then mirror what you did on the driver side.
  7. #7 Re: Driver side door wont open inside or outside what to do !?
    Omaha, NE
    He said he can't open the door though to fix it...
    The cheapest route here might be to pry off the door panel off and try to pull the interior rod hard enough to open the door. With this method, you'll just need a new door panel.
    The more expensive but probably easier route would be to cut yourself a nice sized hole in the outside of the door, and try to pull the rods and open the door that way. Then you'll just need a new door.
  8. #8 Re: Driver side door wont open inside or outside what to do !?
    sounds like the pass door will open, if you re read my post.
  9. #9 Re: Driver side door wont open inside or outside what to do !?
    Omaha, NE
    If he can't open the door, how's he gonna be able to fix the rods?
  10. #10 Re: Driver side door wont open inside or outside what to do !?
    Jan 2014
    AR
    I think by open he meant like take trim panel off, SD.
    Path of least resistance is gonna be to take out the armrest screws and the one behind the courtesy light if applicable, then to pull the trim panel loose at bottom rear and well... work your way in there or get the panel off completely. It might survive if you're careful.
  11. #11 Re: Driver side door wont open inside or outside what to do !?
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Take it to a body shop. They specialize in this kind of thing.
  12. #12 Re: Driver side door wont open inside or outside what to do !?
    you can likely lower the window, then slowly and carefully lift the top of the panel off the rubber block, then remove the rubber and maybe even see the latch.
    opening up the pass side is really just a recon plan for the driver side.
  13. #13 Re: Driver side door wont open inside or outside what to do !?
    Oct 2016
    Fresno CA
    Thanks for the reply il give it whirl tomorrow and post back
  14. #14 Re: Driver side door wont open inside or outside what to do !?
    Oct 2016
    Fresno CA
    Thanks for all the help got it open smoothly replaced the plastic dealy
  1. Passenger Door won't open with either the inside or outside handle
    By nmm2132 in forum General Grand Prix Discussion
    Last Post: 01-25-2016, 11:03 AM
  2. Driver side door won't open
    By Paranoid in forum Visual/Body Modifications
    Last Post: 11-17-2013, 05:01 PM
  3. Replies: 3
    Last Post: 09-09-2013, 10:12 AM
  4. Driver door up, driver side unlock and power mirrors are out!!! Help
    By Dangerous313KidInAPrix in forum Audio, Security & Visual Electronics
    Last Post: 11-25-2009, 12:12 PM
  5. Passenger side door wont open
    By rfmgtp02 in forum General Tech Discussion
    Last Post: 01-05-2009, 01:08 PM
