Thread: Oil Pressure Switch
Results 1 to 7 of 7
  1. #1 Oil Pressure Switch
    SE Level Member lightwalker's Avatar
    Aug 2015
    Hi everyone, this is my first post and I was hoping to get some information. I have a 96 Grand Prix with the 3.1 this has always been a very reliable car, but have already been through replacing intake manifold gaskets twice since we've owned it, recently took it on small trip with interstate speeds, coolant temperatures were normal under 195 degrees until. Pulling in the parking lot at the end of trip and the temp rises to over 220 or so and the oil pressure switch triggers idiot light, it wasn't on solid/steady but flickering, not even an intermediate flash but a flicker. I shut it off let everything cool off and checked fluids, coolant level was good in radiator and overflow tank, oil level perfect level. No milky signs of oil in coolant. I also want add that there was no knocking or ticking from a lack of oil pressure. I want to verify I have good oil pressure but I'm not sure where the oil pressure switch is so I can install a mechanical or electric oil pressure gauge in its place. My big question is the oil pump in the oil pan, I'm wondering if Maybe a pick up tube and screen is plugged. Can someone please help guide me , this is my daily driver aside from my motorcycle and I havnt driven her since problem occured. If it's not getting adequate oil through the engine I'm sure that could explain the higher coolant temperature. Thanks in advance.
    Sent from my VS980 4G using Tapatalk
  2. #2 Re: Oil Pressure Switch
    GXP Level Member
    Mar 2015
    Tomball
    IIRC on the 3.1 it is right near the Oil filter.
    Jeff
  3. #3 Re: Oil Pressure Switch
    Aug 2015
    Just wanted to update on installing the oil pressure gauge in place of the oil pressure switch, after the car was good and warmed up, and at idle, the pressure was 25 lbs which I would think is good, coolant temperature rose to 212 to 215 and the electric fan kicked on bring back down to 195 or so, I'm wondering if this normal for a 100 degree day.
  4. #4 Re: Oil Pressure Switch
    GXP Level Member
    Mar 2015
    Tomball
    Were you just idling in the driveway with the ac off?
  5. #5 Re: Oil Pressure Switch
    Aug 2015
    Yes , I was idleing in the driveway, no air conditioning it hasn't worked in years, so the 2nd fan never comes on ever. I had went around town for few minutes getting car good and warmed up because I had just installed the oil pressure gauge and I wanted to see if the oil pressure switch was just faulty, and I believe it was because I got back and was just idleling in the driveway oil pressure read 25 lbs , but the coolant temp rose to over 210 degrees.
  6. #6 Re: Oil Pressure Switch
    GXP Level Member
    Mar 2015
    Tomball
    Ok that's fine then, your good.
    Jeff
  7. #7 Re: Oil Pressure Switch
    Aug 2015
    Thanks Jeff.
  1. Oil pressure switch?
    By jerrad in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2013, 10:40 PM
  2. 4T65E Manifold Pressure Switch
    By TDgrand in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-15-2012, 09:49 AM
  3. Which Oil Pressure Switch?
    By Pauley in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-22-2012, 05:31 PM
  4. stupid oil pressure switch
    By twol8uluz in forum General Tech Discussion
    Last Post: 09-06-2011, 03:25 PM
  5. Where is A/C pressure switch?
    By PCweber in forum General Tech Discussion
    Last Post: 03-29-2009, 07:13 PM
