Having this issue for a while, when I first start off in the morning, the car warms up, as I am driving, the temp gauge spikes up to 210-220, then goes back to normal, and as I am driving the temp stays around normal, I changed the radiator, cap, water pump, upper and lower intake gasket, flushed the system a bunch of times, bled the system, thermostat, temp sensor, sender, I did everything to try to find why this is doing it, I do know the fan control is bad, I do need to turn the ac on sitting in traffic so the fans kick on to cool the engine, most likely the control module is bad, is it possible the module is causing the spike, or possible head gasket? I am not loosing coolant.
