Thread: Cat and resonator delete
Page 2 of 2 FirstFirst 12
Results 21 to 34 of 34
  1. #21 Re: Cat and resonator delete
    what he said ^^^^ it fakes it out, sometimes you need two of them, but it should work.
  2. #22 Re: Cat and resonator delete
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    The cat test I thought was the car running rich for a bit or however long then looking for it on the rear 02 then it was happy. Which would make the sim not work because it wouldn't read the car running rich so it would be stuck always on. But i have no idea how accurate that is, thats how I've thought it was.
    Sent from BFE
    2012 F150 STX
    - Gonna be a race truck
  3. #23 Re: Cat and resonator delete
    Apr 2012
    Dayton, OH
    Iv gathered that from this post
    http://www.grandprixforums.net/threa...ou-should-know
    Sent from BFE
    2012 F150 STX
  4. #24 Re: Cat and resonator delete
    seems the sims are hit or miss for you 01 up guys. http://www.grandprixforums.net/threa...uld-know/page2
    why not just run a cat? and a res, the res will make it sound better vs not having one...thats been proven
  5. #25 Re: Cat and resonator delete
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    Hm. Good thing both my cars are 00 haha
    04 GTP -HAI, 1.9 rockers.
  6. #26 Re: Cat and resonator delete
    SE Level Member Badgers4life's Avatar
    Mar 2013
    I would pass on the sim.. I wouldn't want to screw around figuring out how well it is or isn't working. Seems like a waste of time and potential money if it goes bad after a little while... I would just replace the cat or clean it out. I changed up my exhaust and actually welded on my old cat because I didn't want to run into these similar problems but was able to eliminate the u-bend which is really what puts a damper in performance.. Not that our cars have much of that anyways..
  7. #27 Re: Cat and resonator delete
    Aug 2013
    Sandy, UT
    If its working no CEL, if its not working, CEL. Pretty standard stuff.....
  8. #28 Re: Cat and resonator delete
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Quote Originally Posted by SnowTh1ef View Post
    Why is that?
    Cat test on 01+ cars can be tuned out with dhp/tiny tuner...
  9. #29 Re: Cat and resonator delete
    Aug 2013
    Sandy, UT
    Because I don't own a tuner. and one car has it tuned out, the other has a sim in it.
  10. #30 Re: Cat and resonator delete
    you can tune the codes to not report, but 01 up years keeps f ing up and causing the fuel trims to be off.
  11. #31 Re: Cat and resonator delete
    Dec 2011
    Ontario,Canada
    did you look at my post above?
  12. #32 Re: Cat and resonator delete
    did you read the link i posted? they all pretty much said it still sends off poor ltft's. sim's can help, or not. the 01 is different then the 97-00 cars as far as the rear 02 goes.
  13. #33 Re: Cat and resonator delete
    Dec 2011
    Ontario,Canada
    No
    You still havn't looked at my post close enough.
    I'm not just talking about setting the rear o2 to no report with dhp
    With Tiny tuner you can set the number of cat tests per trip on an 01+ car to zero
    Therefore no cat test happens and no extra fuel to screw up the LTFT's
  14. #34 Re: Cat and resonator delete
    if that works, post that to that thread there lol
  1. Resonator delete or no Resonator delete
    By 3800 Man in forum General Tech Discussion
    Last Post: 03-05-2014, 08:34 PM
  2. resonator delete or not?
    By Rigg23 in forum General Grand Prix Discussion
    Last Post: 03-08-2013, 07:48 PM
  3. Resonator delete?
    By Curt7 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-15-2012, 06:24 PM
  4. U Bend Delete & Resonator Delete
    By 9ordohz in forum General Tech Discussion
    Last Post: 10-23-2010, 10:57 AM
  5. Resonator delete?
    By jagamite in forum General Tech Discussion
    Last Post: 01-17-2009, 05:41 PM
