Thread: no start
Results 1 to 14 of 14
  1. #1 no start
    SE Level Member Snoop dogg's Avatar
    Dec 2013
    chicago
    Hey need some help here I have a 02 grand Prix se and I just did a LIM gasket and now the car won't start and when I try to start the car it back fires out the intake any one know what I did wrong
    ....::::THE DREAMER::::....
  2. #2 Re: no start
    WRong order on the plugs wires is my guess and unplugged injectors.
    Front is 1,3,5, rear is 2,4,6.
  3. #3 Re: no start
  4. #4 Re: no start
    Dec 2013
    chicago
    I have a Grand Prix SE with a 3.1 engine
  5. #5 Re: no start
    Plug order should still be the same for front and back, just something to double check.
  6. #6 Re: no start
    popping out the intake is almost always crossed plug wires.
  7. #7 Re: no start
    Jun 2011
    Texas
    I agree that spark plug wires installed on the wrong cylinder is the most likely cause of popping through the intake. The cylinder location on a 3.1 is different than a 3.8. The front bank is 2,4,6 and rear bank is 1,3,5. Here are some pictures from Alldata:
    The other possibility is you did not put the pushrods in the correct spots. The intake pushrods are shorter than the exhaust pushrods.
    no start Attached Images
  8. #8 Re: no start
    Hmm, the **** GM. Every other motor is 1,3,5 on the front bank or left bank lol.
  9. #9 Re: no start
    It's a 3.1 Cam.. on the GA's they made sure you couldn't see the coils well enough to notice..lol
  10. #10 Re: no start
    Mar 2012
    NC
    I've done one of these where the lifters wouldn't collapse when reinstalling the pushrods causing it to sound like no compression and popping out the intake. I ended up loosening up the rocker arms slightly which closed the valves, started the car, then torqued them down. Worked like a charm. This was my last resort stuff though. Obviously check the other stuff posted first.
  11. #11 Re: no start
    Mar 2012
    NC
    Snoop must be doing pretty bad these days...went from blunts, 40's, and b!tches to driving a 3100 GP...these are surely sad times.
  12. #12 Re: no start
    Dec 2013
    chicago
    Lol
  13. #13 Re: no start
    Dec 2013
    chicago
    okay I got it to start today apparently there was no fuel pressurebut the other thing is it idles a little low like its going to cut off but when I unplug the mass airflow sensor it idles a little too high I did take one of the plugs out and it looked a very bad do you guys think I should change the plugs first or do you guys think is the MAF
  14. #14 Re: no start
    Did you put that vacuum tube on top of the TB back in place? IIRC it's not easy to see the hole due to a bracket on the TB. But if it's missing, you'll have a hell of a time.
    My car sounded cammed yesterday. hooked the brake booster back up and it purrs.. odd how that works.
  1. 1993 grand prix 3.4 wont start have to pump gas to start
    By lookout in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-27-2015, 05:45 AM
  2. Are you ever to old to start having fun again...?
    By JustanAlias in forum Introductions/Noob Questions
    Last Post: 05-14-2012, 02:58 PM
  3. no start
    By b4322558 in forum General Tech Discussion
    Last Post: 02-25-2011, 04:01 PM
  4. Won't start! Please help!
    By fpgt17 in forum Off Topic Discussion
    Last Post: 01-22-2011, 12:10 AM
  5. Won't Start
    By 06grandprix93 in forum General Tech Discussion
    Last Post: 01-20-2011, 04:00 AM
