Thread: 99 GP 3100 engine noise
Results 1 to 14 of 14
  1. #1 99 GP 3100 engine noise
    Jun 2014
    Canada
    Just got this 99 guy told me it needed a fuel pump (it did),started it up,thought the tick tick was the familiar piston slap I've heard on so many 3.1's.But as the engine warmed up the noise didn't go away.I can make the noise stop by disconnecting the plug wire to the center plug on the front(is that #2 or #4?).Is this a rod knock or could the valve train,say a collapsed lifter be causing this?
  2. #2 Re: 99 GP 3100 engine noise
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    If you can get a video and upload it, it would help a lot.
    2012 F150 STX
    - Gonna be a race truck
  3. #3 Re: 99 GP 3100 engine noise
    Dec 2012
    troll land
    Have you checked that plug is torqued down correctly? A leaking plug could cause a tick
  4. #4 Re: 99 GP 3100 engine noise
    Could be an exhaust leak too.
  5. #5 Re: 99 GP 3100 engine noise
    Jun 2014
    Canada
    Here's a video. Loud noise goes away with #4 plug unplugged,still has noise,possibly the normal piston slap.
  6. #6 Re: 99 GP 3100 engine noise
    canal winchester, ohio
    Did you ever figure this out?
  7. #7 Re: 99 GP 3100 engine noise
    Buffalo
    Bearing
  8. #8 Re: 99 GP 3100 engine noise
    Jun 2014
    Canada
    Quote Originally Posted by michael redmon View Post
    Gave the car to my daughter as is,she`s been driving it as is for the last 2 years,even some long trips (6 hours).Noise never gets worse,engine has good power.Embarrassing when you start it in a parking lot full of people,but she doesn`t seem to mind.
  9. #9 Re: 99 GP 3100 engine noise
    Buffalo
    I think bearing because when you removed the combustion force from that cylinder , the knock went away
    when the oil warms up and you build pressure the knock goes away
    so I suspect rod bearing
  10. #10 Re: 99 GP 3100 engine noise
    GT Level Member mguzzo's Avatar
    Buffalo NY
    ^^ thinking the same thing. clearly a rod knock
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  11. #11 Re: 99 GP 3100 engine noise
    Funny it keeps rolling along. My car is loud as heck also but runs nice.
  12. #12 Re: 99 GP 3100 engine noise
    So this is basically my car also except the noise only occurs under load. So if at idle and I rev the engine the. Nothing. Driving under load and I give it gas I get.the noise.
    Any ideas? I would like to fix it.
  13. #13 Re: 99 GP 3100 engine noise
    Buffalo
    Well like stated above or flex plate are tso possibilities
  14. #14 Re: 99 GP 3100 engine noise
    New York
    Sounds like a valve train noise..a.rod knock is usually a lower sounding thump...that sounds like a lifter or valve...did you pull the valve covers and inspect and run the engine?
  1. 3100 engine swap to 3800
    By carlover89 in forum General Grand Prix Discussion
    Last Post: 06-30-2014, 12:04 PM
  2. Can I put a 02 3100 SE engine and tranny in a 97 gt body?
    By willalmo in forum General Tech Discussion
    Last Post: 06-07-2014, 11:28 PM
  3. Has anyone replaced fuel injectors on a 3100 (3.1) engine?
    By gpbastard in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-14-2012, 06:16 PM
  4. 2003 GP 3100 engine
    By rmr989 in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-26-2009, 05:21 PM
  5. 1997 Monte Engine Swap (3.1 3100 V6)
    By StreetChariot in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-25-2008, 08:06 AM
