Thread: exhaust kits for a 3.1
Results 1 to 12 of 12
  1. #1 exhaust kits for a 3.1
    SE Level Member NEONNIGHT34609's Avatar
    Dec 2008
    florida
    i have a 2002 grand prix 3.1 i am looking for a cat-back system for it .. i seen this but it does not specify if its for the 3.1 or 3.8 i am finding that alot .. are they the same application or is there differences .. thanks
    Borla Cat-back Exhaust - 97-03 Grand Prix 14803 - PFYC
  2. #2 Re: exhaust kits for a 3.1
    Ummm...do a L67 swap and buy the catback for a GTP
  3. #3 Re: exhaust kits for a 3.1
    May 2008
    staten island,NY
    Milzy Motorsports - American Muscle, Reborn
    try him out he specializes in 3100/3400's
  4. #4 Re: exhaust kits for a 3.1
    Donating Users RareGMFan's Avatar
    Dec 2008
    Naperville, IL
    The motor doesn't matter. So long as you have the same dual y-pipe exhaust as the GTs and GTPs (which an '02 SE should have), it should all be the same.
    PREVIOUS: '89 Pontiac 6000 STE AWD (2/1376), '90 Pontiac GP SE McLaren Turbo (1/2749)
    '90 Pontiac Grand Prix STE McLaren Turbo (1/1000), '01 Pontiac GP GTP Special Edition (1/1341)
    CURRENT: '00 Pontiac Grand Prix GTP (ugh...boring regular one)
  5. #5 Re: exhaust kits for a 3.1
    Oct 2008
    mascoutah, Il
    may I ask why you are looking for a cat back system for a 3100? No sarcasm intended but just curious if you are needing a higher flowing exhaust for mods or just better sound?
    2002 GTP
    custom HOK paint
  6. #6 Re: exhaust kits for a 3.1
    Dec 2008
    florida
    just looking for a better sound and wanting the dual exhaust .
  7. #7 Re: exhaust kits for a 3.1
    Dec 2008
    Naperville, IL
    The GM 60° motors sound bad ass for being a V6, anyway (FAR better than the 90° motors). You can't go wrong with any mufflers as far as sound. But do you not have dual outlets already?
  8. #8 Re: exhaust kits for a 3.1
    Oct 2008
    mascoutah, Il
    get a factory dual setup if you dont already have one and just replace the mufflers with pipe, but leave the resonator on. Sounds as good as flowmasters and alot cheaper. I had the setup on my 96 with a 3400 swap, loved it.
    2002 GTP
    custom HOK paint
  9. #9 Re: exhaust kits for a 3.1
    Dec 2008
    florida
    can i use a dual setup from any grand prix of my years regardless of engine as long as its a 6 cylinder of course
  10. #10 Re: exhaust kits for a 3.1
    SE Level Member Berger's Avatar
    Feb 2008
    New Philadelphia, Ohio
    If you get one froma a junkyard you will want an exhaust from a 97-03. If you get one from an older gp the pipe they used back then is smaller than the newer ones. I dont run a resinator and it sounds good on my 3100 fyi
    2003 Grand Prix SE / Redfire Metallic
    GT/GTP body conversion - 3"FWI - 56mm TB - AGX/SSC combo - 077's - GMPP front/rear sway bars - GMPP trailing arms - GMPP front/rear STB with DR brackets - 03 Limited Edition spoiler - 12" Front Brakes
  11. #11 Re: exhaust kits for a 3.1
    Oct 2008
    mascoutah, Il
    Quote Originally Posted by Berger View Post
    Cat only then? Removing res make much of a difference on loudness or just tone?
    2002 GTP
    custom HOK paint
  12. #12 Re: exhaust kits for a 3.1
    Feb 2008
    I run the cat only. People say that the res keeps rasp down but i dont have rasp or a res. I think its a little bit of both. (tone/loudness) Ialso run the cheap summit brand mufflers and i think it gives the perfect sound, not to quiet and not to loud.
  1. HID Kits
    By webracin in forum Group Buys
    Last Post: 07-08-2009, 10:26 PM
  2. Shift kits...
    By Bogers99GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-03-2008, 12:34 PM
  3. BEST HID kits ever, BEST price
    By scoobyydooooooo in forum Visual/Body Modifications
    Last Post: 03-17-2008, 08:22 PM
