Thread: Hard start when hot, smell of fuel
Results 1 to 14 of 14
  1. #1 Hard start when hot, smell of fuel
    Jun 2013
    baltimore, md
    After learning my lesson here, I figure I'll ask first, before I go start trying to figure things out. This problem is still in the same car. It ran good for a short time, but now it's taking a long time to start when hot, and there's a smell of gas. I've checked the fuel filter, and it's not leaking. In that post above, I checked the fuel pressure, it seemed fine, but I know that's not a complete thorough test, and it could be still bad.
    I'm thinking it's the Ignition Control Module or the Fuel Pump. I'm HOPING it's the ICM, simply because it's cheaper. (ICM is 100$, the fuel pump is $250)
    Thoughts? Opinions?
    Thanks for your time,
    Robert
  2. #2 Re: Hard start when hot, smell of fuel
    Check your fuel pressure grab a fuel pressure tester from HF.
    04 Comp G.
  3. #3 Re: Hard start when hot, smell of fuel
    Jun 2011
    Texas
    It is common for the fuel pressure regulator to leak. Sometimes it is intermittent. The regulator is just forward the throttle body. I had the fuel pump cause an extended crank on my 97 GT only when hot also.
  4. #4 Re: Hard start when hot, smell of fuel
    Jun 2013
    baltimore, md
    I've actually replaced the fuel pressure regulator. And I've checked the fuel pressure, and it was fine both before and after changing the fuel pressure regulator.
    It's a 98 Pontiac Grand Prix SE, 3.1L.
    I've recently replaced:
    Harmonic Dampener (It was wobbling like crazy)
    Crankshaft Position Sensor (thought it would fix another problem)
    Tested all the Coils with a known good coil
    Spark Plugs
    Plug Wires
    Fuel Pressure Regulator
    Fuel Filter
    Several vacuum hoses
    Vacuum level is steady
    Repaced wire from ICM to rear crankshaft position sensor
    Starter
    I used the fuel pressure gauge that you can borrow from AutoZone.
    Robert
  5. #5 Re: Hard start when hot, smell of fuel
    Jun 2011
    Texas
    Did you have the fuel pressure gauge on it when it acted up? What was the pressure? Did the fuel pressure drop after the cars was turned off? When and where do you smell gas?
  6. #6 Re: Hard start when hot, smell of fuel
    Jun 2013
    baltimore, md
    Your questions have made me start thinking it might be the fuel pump. I know the place to get to the pump is in the trunk, and that could very well be where the smell is coming from, because the odor is inside the car.
    I'm going to tape up the opening, and see if that removes the smell. If it does, it sounds like that's where the problem is. If that's the case, does this mean I'll have to replace the fuel pump? Or is it maybe a seal of some sort? Or maybe the return line is causing problems?
    Thanks for your help and time,
    Robert
  7. #7 Re: Hard start when hot, smell of fuel
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Check to make sure the pump runs when you turn the key into the on position, also when you smell gas pop the hood and smell around to find where it is coming from even around the whole car.
    Sent from my Galaxy Tab 3 8.0
    2012 F150 STX
    - Gonna be a race truck
  8. #8 Re: Hard start when hot, smell of fuel
    Jun 2013
    baltimore, md
    I know the pump runs when you turn on the key. I've asked her to wait a few seconds for that to complete, hoping it might help the car start. I'm thinking the smell of gas is coming from the trunk. I duct taped the area that's right above the fuel pump, thinking maybe the fuel smell is leaking through. If that doesn't work, I'll empty the trunk of everything, and see if that helps, I'm doubtful it will, but I want to eliminate everything.
  9. #9 Re: Hard start when hot, smell of fuel
    Apr 2012
    Dayton, OH
    Could possibly be leaking on the top of the tank, remove the access panel and check it out. Its only a handful of bolts.
    2012 F150 STX
  10. #10 Re: Hard start when hot, smell of fuel
    Jun 2013
    baltimore, md
    Once again, I'm glad I checked on here and listened to what ya'll had to say.
    The @#%@#%@#$ fuel pressure regulator - not EVEN a month old - the diaphram or whatever inside went bad. It was leaking gas into the vacuum. What's worse, the vacuum line had melted, and it was leaking gas - explains the gas smell. The leaking vacuum explains hard to start, as well as the loss of fuel pressure.
    I took it back to AutoZone and got a replacement, it was still under warranty.
    Thanks again for your time and help. Now if only I can figure out the problem with the other car, the 5V reference voltage problem.
    Robert
  11. #11 Re: Hard start when hot, smell of fuel
    SE Level Member notchy's Avatar
    Aug 2012
    Okotoks
    get the pcm flashed when the new crank position sensor installed??
  12. #12 Re: Hard start when hot, smell of fuel
    Jun 2011
    Texas
    The PCM does not need to be re-flashed after a crank sensor is replaced. There is a crankshaft variation learn that should be done. This is a special test that is done with an OEM level access scan tool.
  13. #13 Re: Hard start when hot, smell of fuel
    Aug 2012
    Okotoks
    i was told otherwise... so ill go smack him , cheers lol
  14. #14 Re: Hard start when hot, smell of fuel
    you only need the crank sensor re learn if the cel lights up. or it wont start up. if it fired up, and runs right now, and no cel, your all set crank sensor wise. carry on.
  1. Hard to start Fuel pump?
    By ksgunner33 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-11-2013, 12:24 PM
  2. need help w 08 gp. oil smell under hard acceleration.
    By 08 gp lvr in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-26-2012, 01:07 PM
  3. Smell gas/fuel on rear driver above tire
    By rocket in forum General Tech Discussion
    Last Post: 06-14-2012, 07:37 PM
  4. fuel vapor smell....
    By Vegas~Blown in forum General Tech Discussion
    Last Post: 09-01-2008, 10:45 PM
  5. 2000 GP SE rich fuel smell out of vents this morning.
    By StreetChariot in forum General Tech Discussion
    Last Post: 04-29-2008, 08:54 AM
