Thread: Harmonic balancer problem
Results 1 to 11 of 11
  1. #1 Harmonic balancer problem
    GTX Level Member 94grandprix's Avatar
    Jul 2010
    Crandall, Georgia, United States
    Ok I knew the harmonic balancer on our 03 gp se was due for a change but I left and got about 7 miles from my house and I lost my power steering and pulled over and my pulley was sitting on the sub frame,the belt was actually still on it so I drove it home with no issues,his will I get the balancer off now since the puller usually goes on the pulley?
  2. #2 Re: Harmonic balancer problem
    Might have quite the problem there. Take a pic and post it up
  3. #3 Re: Harmonic balancer problem
    Jul 2010
    Ok I haven't took the tire off yet,i may go out there in a few and take one
  4. #4 Re: Harmonic balancer problem
    SE Level Member pontiac4lifesc's Avatar
    Mar 2012
    Winona, MN
    if its the outer part your fine because you use bolts that go into the balancer to get it off. its almost like a steering wheel puller where the center threaded shaft forces it off when you tighten it.
  5. #5 Re: Harmonic balancer problem
    hangover park IL
    the hub of the damper with the puller bolt threads is separate from the outer damper ring. plenty of times ive had the two seperate at the rubber bond and spin so that the outer ring had the access slots covering the bolt threads...ive had to spin the outer ring or use a prybar to open up the slots so that you can install the 3 bolts
    if the whole outer ring fell off you should have the easiest time in the world removing it since youll actually be able to see the bolt holes instead of "feeling" for them through those pesky slots
    ~James~ Psychotic Gearhead
  6. #6 Re: Harmonic balancer problem
    hangover park IL
    lol thought this was the 3800. the 3100 is similar just withou the slots so youll have no problem
  7. #7 Re: Harmonic balancer problem
    Jul 2010
    http://i1121.photobucket.com/albums/...pspfxi4rh5.jpg here it is,now seeing it looks like my puller will work but to be sure what size are the bolts and fine or corse thread,the car looks rusty but it ain't it's just mud,thanks any help is appreciated
  8. #8 Re: Harmonic balancer problem
    hangover park IL
    it should be an 8mm x 1.25 or 10mm x 1.5 threads iirc
  9. #9 Re: Harmonic balancer problem
    Jul 2010
    Ok fine or corse
  10. #10 Re: Harmonic balancer problem
    hangover park IL
    with metric its thread pitch which is the second set of numbers , in mm... between the thread peaks is 1.25mm on the 8mm and 1.5mm pitch on the 10mm.
  11. #11 Re: Harmonic balancer problem
    Jul 2010
    Ok so I should get both and see which one goes in easiest
  1. Harmonic balancer
    By Tone5500 in forum General Tech Discussion
    Last Post: 11-13-2013, 08:01 AM
  2. Well there goes my L67 harmonic balancer...
    By jlgp2007nc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-07-2013, 02:44 PM
  3. new harmonic balancer, now got KR
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-06-2012, 07:31 AM
  4. help with harmonic balancer
    By Alcalypse in forum General Tech Discussion
    Last Post: 01-13-2011, 09:04 PM
