Thread: Bubbles in coolant???
Results 1 to 11 of 11
  1. #1 Bubbles in coolant???
    May 2013
    Michigan
    I have the given engine. My Grand Prix has been acting weird. Getting hot and only once overheating. I noticed when I have it running the coolant in the reservoir bubbles. Even if it has been running long enough to get the air out of the cooling lines. The hoses are stiff (I imagine this is normal due to the pump). It isn't violent bubbles but they are rapid. When I first start the engine it is light then it gets worse when I drive it. I don't think it is the head gasket due to the fact I don't overheat and that I don't have smoke or steam coming out the exhaust.
  2. #2 Re: Bubbles in coolant???
    Could be the intake gasket going bad and it's low on coolant.
  3. #3 Re: Bubbles in coolant???
    May 2013
    Michigan
    Well I spoke with a mechanic friend of mine. He says its most likely the head gasket or the lower intake manifold gasket. There is no coolant in the oil or the other way around. A large amount of pressure builds up in the coolant system.d
  4. #4 Re: Bubbles in coolant???
  5. #5 Re: Bubbles in coolant???
    Dan, How's a LIM gasket issue possible to cause bubbles?
  6. #6 Re: Bubbles in coolant???
    Low coolant causing air bubbles
  7. #7 Re: Bubbles in coolant???
    SE Level Member Jcinstalls's Avatar
    Feb 2013
    Missoula, MT
    How did this problem turn out?
  8. #8 Re: Bubbles in coolant???
    GTP Level Member WhiteLightningGTP's Avatar
    Nov 2012
    Frankenmuth, MI
    Quote Originally Posted by Jcinstalls View Post
    Same way the project went with the guy putting thick gear oil into his SC....
  9. #9 Re: Bubbles in coolant???
    May 2013
    Michigan
    Well turns out it was the head gasket blue devil to the rescue saved me from having to pull the heads. Tranny is what killed the gasket going to sell that car for cheap dont have the money to deal with it (not going to scam them). Thanks everyone.
  10. #10 Re: Bubbles in coolant???
    How do you think the trans caused the head gasket to go bad?
  11. #11 Re: Bubbles in coolant???
    May 2013
    Michigan
    Got a little frustrated and left the pedal down one day. If I leave it down It wont shift due to what I think it is a bad/weak torque converter. It was getting hard to get up to freeway speeds. Not a very smart choice on my part. I paid for it later on.
  1. Is it normal to have bubbles on the transmission dipstick?
    By Coldwaves in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-07-2013, 10:16 PM
  2. Flashing Low Coolant Light, Coolant Full, No leaks
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-12-2012, 08:25 PM
  3. Small bubbles in trans fluid
    By Gasnmyveins in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-28-2011, 11:27 PM
  4. Rust Bubbles
    By ljmonnin12 in forum Visual/Body Modifications
    Last Post: 03-08-2011, 01:47 AM
  5. Bubbles in coolant/ radiator
    By PCweber in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-08-2009, 12:27 PM
