Thread: need help!! revised.
Results 1 to 4 of 4
  1. #1 need help!! revised.
    Mar 2015
    Tyler Texas
    Ok so putting this in a new thread simply to get fresh ideas. I have a 98 grand prix se 3.1 L. Replaced head, manifold gaskets and a few other worn parts. Go to start and it wont start. Cranks but wont start. Double check and still no start. It did start on 2 different occasions. Turn it off and wont start again. So I check the timing chain.. take it off and re adjust the timing put everything back and wont start. Turn the crank pully by hand and it only goes a little then stops. Same in the other direction. All plugs are out ! So its not comppresion. I tuned the valves after replacing the head gaskets. But if the timing was off and now has been reset, could the valves be causing it not to turn? And need to be retuned?
  2. #2 Re: need help!! revised.
    why did you move the timing chain? put that back where it was, the valves are likely hitting the pistons, and thats why it will turn and then stops.
  3. #3 Re: need help!! revised.
    Mar 2015
    Tyler Texas
    I realigned the timing to the specifications as they state in the chilton for the gm 3100. And I thought the 98 was a no interference motor.the crank turns 348 degrees in both directions and stops
  4. #4 Re: need help!! revised.
    Mar 2015
    Tyler Texas
    Correction 358
  1. 04+ GP revised headlight bracket??
    By Alix0r in forum Visual/Body Modifications
    Last Post: 01-03-2013, 09:07 PM
