Thread: 2002 transmission slight Buck?
Results 1 to 5 of 5
  1. #1 2002 transmission slight Buck?
    SE Level Member BigBadDodge's Avatar
    Feb 2013
    Minnesota
    I just got this car and the transmission kind of bucks when I let off the gas or there is troubles getting power to pass people. I don't want issues with this car it's all I've got to drive
    ~If it slips it slides.
  2. #2 Re: 2002 transmission slight Buck?
    If it was my car, I would clean the MAF sensor up and then do a pan drop and filter change with a bottle of lucas and 7 quarts of trans fluid.
    Its the first thing I would do, then if it still acts the same we can go from there.
  3. #3 Re: 2002 transmission slight Buck?
    Feb 2013
    Minnesota
    Where's the MAF at and what would you clean it with? Also transmission additive?
  4. #4 Re: 2002 transmission slight Buck?
    The MAF sensor is just after the air box in the rubber tubing. You clean it with maf cleaner, they sell it at any auto parts store.
    The bottle of lucas I guess you could say its a additive, alot of us just add it regardless because its proven to work good.
    Here is a pic of the MAF.
  5. #5 Re: 2002 transmission slight Buck?
    SE Level Member Jcinstalls's Avatar
    Feb 2013
    Missoula, MT
    Ive had issues with my torque converter solenoid that sound similar to bucking transmission. I guess its a typical GP thing and it cost me 650$ for a new torque converter, a bunch a internal trans solenoids, a shift kit that " fixes" the exact issue and a mechanic to do it all. It was an extremely bad shutter when shifting while it was at op temp. I don't think your haven the same issue but keep it in mind.
  1. Bang for the buck!
    By JunkBird69 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-04-2011, 12:01 AM
  2. Best bang for buck?
    By Edagimo in forum Engine
    Last Post: 06-16-2010, 09:22 PM
  3. Modding 2002 GTP Transmission
    By gtp02 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-09-2010, 12:13 AM
  4. Low buck carputer.
    By 16MustangVet in forum Audio, Security & Visual Electronics
    Last Post: 11-24-2009, 08:09 AM
  5. Best Bang for your buck on speakers?
    By RichCresci in forum Audio, Security & Visual Electronics
    Last Post: 10-02-2008, 04:49 PM
