Thread: Timing Chain cover
Results 1 to 6 of 6
  1. #1 Timing Chain cover
    Jan 2013
    Chicago
    Chats
    Hey all! so i am noticing a small oil leak on the bottom of my car. It's on the front left side of the engine if you are looking at it from the front. I had the LIM gasket replaced a few years ago and i'm thinking it's around the Timing Chain cover. I was wondering what the difficulty is of taking it off? also is there a gasket for the chain cover?
    Thanks!
  2. #2 Re: Timing Chain cover
    Jan 2013
    Chicago
    Chats
    also, 2000 3100 SE with around 138k miles on it.
  3. #3 Re: Timing Chain cover
    Chats
    98246
    There is a gasket and it can definately be leaking. Not sure on difficulty.
  4. #4 Re: Timing Chain cover
    Jan 2013
    Chicago
    Chats
    Thanks Bill, of course the place i took it said it would cost around 700 to fix including a new chain. I'm not sure if i need to replace the chain just fix the leak. i've done some easier stuff on this car so far, replaced water pump, replaced thermostat (which was kind of a b*tch) under the throttle boddy. spark plugs etc. if it's just a gasket replacement it would be cheaper to do it myself assuming the time/effort is worth it
  5. #5 Re: Timing Chain cover
    Chats
    98246
    As I remember when my buddy (mechanic) did my Dad's in his Grand Ammo, I'm pretty sure he was bit chin about how it sucked.
  6. #6 Re: Timing Chain cover
    Jan 2013
    Chicago
    Chats
    Thanks a lot, Bill!
  1. 3.1 timing chain
    By bybeecl in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-01-2011, 11:56 AM
  2. Timing Chain cover
    By timboku in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-14-2010, 10:02 PM
  3. timing Chain
    By Zach3800 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-21-2010, 11:12 PM
  4. Which timing chain to get.
    By PWNED in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-20-2008, 09:01 AM
  5. Which timing chain?
    By whitcomb in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-01-2008, 04:49 PM
