Thread: new water pump now car is over heating
Results 1 to 20 of 39
  1. #1 new water pump now car is over heating
    Dec 2012
    United States
    well my wife was driving the car other day and the water pump decided to seize and drove it hot for 10 miles she was in the hood. well i replaced the water pump thermostat and radiator cap. well went put in stright antifreeze and opened both air valves to let air out well now my service engine light comes on randomly and runs like **** smokes bad and smells like rubber. i know i can drive it to advanced to check it but it wont make it around the block without over heating also no heat eather. i need help asap i got to report back in by weds please help
  2. #2 Re: new water pump now car is over heating
    GT Level Member GTX's Avatar
    Apr 2008
    Vallejo,Ca
    id say make sure you purged all air out the cooling system .... turn on the heater and let it warm up..eventually it should burp itself...if not...you might have blown a head gasket on your hands...
    COMP G
  3. #3 Re: new water pump now car is over heating
    Dec 2012
    United States
    it just werid how it drives fine for a little while then like **** if it was head gasket wouldnt wouldnt it run like **** all the time
  4. #4 Re: new water pump now car is over heating
    Dec 2012
    United States
    also oil looks fine no white smoke it like black
  5. #5 Re: new water pump now car is over heating
    turning the heater on is of no help, coolant flows to the core all the time. the core could be air locked and needs to be flushed. take both hoses off the alt bracket, and then flush with a garden hose.
    but that wont cause over heating. chances are you have air still in the engine (you need to bleed it when the engine is warmed up enough to open the t stat.)
    you can also take the t stat housing back off and fill the engine from that hole, till its full, then put the t stat back in, make sure its not upside down too.
    do not use straight antifreeze either, unless its the 50/50 blend pre mixed.
    i use one gallon of full strength coolant, and top off with hose water.
  6. #6 Re: new water pump now car is over heating
    Dec 2012
    United States
    what best wait to tell if head gasket is blown
  7. #7 Re: new water pump now car is over heating
    one of these works
    and if you rev the engine when its warmed up if you see bubbles in the rad, cap open of course.
    or do a compression test.
  8. #8 Re: new water pump now car is over heating
    Donating Users JLiss's Avatar
    Dec 2012
    Aurora, IL
    best way to check if you blew a head gasket is for oil to be in your coolant resevoir.
  9. #9 Re: new water pump now car is over heating
    Dec 2012
    United States
    no oil in it .when i start up the car a big thing of water came out after it didnt
  10. #10 Re: new water pump now car is over heating
    Dec 2012
    Aurora, IL
    are you sure did you remove the resevoir and pour some out, dont go off eye contact. is it blue smoke? or white smoke? what does the smoke smell like?
    next drain some oil, and check for coolant as well.
  11. #11 Re: new water pump now car is over heating
    Quote Originally Posted by JLiss View Post
    that is almost impossible to happen.
    head gaskets when blown eat coolant. ask me how i know?
  12. #12 Re: new water pump now car is over heating
    Dec 2012
    United States
    blue and smells like plastic
  13. #13 Re: new water pump now car is over heating
    Dec 2012
    United States
    ill take video in morning
  14. #14 Re: new water pump now car is over heating
    blue smoke and smells out the tail pipe?
  15. #15 Re: new water pump now car is over heating
    Dec 2012
    Aurora, IL
    Quote Originally Posted by csanderlin View Post
    it is HARDLY impossible my friend that is the one trick to see if you in-deed blew a headgasket, is it POSSIBLE there isnt any oil in there with a blown head gasket yes.
    another thing you can do is Remove dipstick and let a drop of fluid fall on hot part of engine - oil will smoke water will "sizzle", if blue smoke is coming out the tail that is a sign that oil is burning.
  16. #16 Re: new water pump now car is over heating
    the only real way oil is getting into coolant is from a blown oil cooler in the radiator. these car dont usually have that option.
    coolant in the oil pan can happen. but it would also have to seep in through the pistons, past the rings, and im sure it would of hydro locked long before you found coolant in the oil.
    if you see sludge in the over flow, thats dex coolant residue.
    Quincy, Mass
    That's correct, coolant is water with some antifreeze and some other chemicals but its mostly water, it will steam clean your cylinders and won't make it back to the reservoir. Or it will drain down into the oil pan. Dexcool likes to sludge up and it looks like it could be oil, especially if a different color coolant has been added to top it off.
    No more GP 04 Impala SS Indy:
  18. #18 Re: new water pump now car is over heating
    Dec 2012
    United States
  19. #19 Re: new water pump now car is over heating
    that looks like its over heating bad in the vid. take the t stat out, and run it again if the same thing is happening, id say the head gaskets are blown for sure.
  20. #20 Re: new water pump now car is over heating
    Dec 2012
    United States
    ok ill try it tomorrow should i try stright water till i figer it out or do mix
  1. water pump
    By redlinepontiac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-27-2012, 07:57 AM
  2. Water pump
    By robblk04 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-01-2011, 03:18 PM
  3. Water Pump???
    By armyrebel03 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-12-2011, 11:26 PM
  4. Water Pump Help
    By thewaitinggame in forum General Tech Discussion
    Last Post: 02-18-2011, 07:57 PM
  5. Water pump ?
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-10-2008, 01:21 PM
