Thread: new water pump now car is over heating
Page 2 of 2 FirstFirst 12
Results 21 to 39 of 39
  1. #21 Re: new water pump now car is over heating
    that depends on how cold its gonna get where you live.
    below freezing id use antifreeze.
  2. #22 Re: new water pump now car is over heating
    how hot was the temp gauge while running in that vid you posted?
  3. #23 Re: new water pump now car is over heating
    GT Level Member GTX's Avatar
    Apr 2008
    Vallejo,Ca
    not in all cases will coolant and oil mix...and those block testers are known to sometimes deliver false readings, showing a head not to be blown
    the fact that the car was driven 10 miles on seized water pump while overheating and now has developed a misfire...99% chance the head is blown
    COMP G
  4. #24 Re: new water pump now car is over heating
    Dec 2012
    United States
    it wasnt even over heating yet
  5. #25 Re: new water pump now car is over heating
    Dec 2012
    United States
    found out it wasnt 10 miles it was 2 miles
  6. #26 Re: new water pump now car is over heating
    Dec 2012
    United States
    ok werid this morning started it up had to get baby food or i was going to shot my self. well it ran fine no service engine light no over heating what the hell
  7. #27 Re: new water pump now car is over heating
    bad t stat maybe.
    like i said, you vid looked like it was over heating. locked up t stat can do that.
  8. #28 Re: new water pump now car is over heating
    Apr 2008
    Vallejo,Ca
    How cold and how far was the drive ?
    COMP G
  9. #29 Re: new water pump now car is over heating
    Dec 2012
    United States
    it got to 180-190 and drove 5 miles and i have put on 2 therm
  10. #30 Re: new water pump now car is over heating
    Dec 2012
    United States
    question of day if it blown head gasket should i change both or it ok do one side that blow bec i know they are separated
  11. #31 Re: new water pump now car is over heating
    if your doing one side, id do the other as well. your in so deep already.
  12. #32 Re: new water pump now car is over heating
    Apr 2008
    Vallejo,Ca
    Quote Originally Posted by csanderlin View Post
    best to do both sides together
    COMP G
  13. #33 Re: new water pump now car is over heating
    Donating Users JLiss's Avatar
    Dec 2012
    Aurora, IL
    isnt another way to check, is to see if the hose on the right side of motor is just as hot as the left side hose, thats how i noticed my car needed a thermostat, the house on the right side of engine bay was hot, and the other side was "warm"
  14. #34 Re: new water pump now car is over heating
    if your talking about the fat rad hose's, the top one should be hotter then the lower one, as the lower is cooled coolant that flows back to the engine.
  15. #35 Re: new water pump now car is over heating
    Dec 2012
    Aurora, IL
    interesting, that makes sense, once i swapp'ed them they both retained warm.
  16. #36 Re: new water pump now car is over heating
    Dec 2012
    United States
    i used the blue devil and it worked
  17. #37 Re: new water pump now car is over heating
    ive seen vids of people using blue devil and it working. i may give it a shot myself, as i eat a cup of coolant a day with my car.
  18. #38 Re: new water pump now car is over heating
    im looking into this stuff, what size bottle did you use, 16 or 32 OZ?
  19. #39 Re: new water pump now car is over heating
    SE Level Member sharpboat01's Avatar
    May 2013
    Gwinn, MI
    Purge air out of cooling system, you have bleeder valves and a purge funnel works great!
  1. water pump
    By redlinepontiac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-27-2012, 07:57 AM
  2. Water pump
    By robblk04 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-01-2011, 03:18 PM
  3. Water Pump???
    By armyrebel03 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-12-2011, 11:26 PM
  4. Water Pump Help
    By thewaitinggame in forum General Tech Discussion
    Last Post: 02-18-2011, 07:57 PM
  5. Water pump ?
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-10-2008, 01:21 PM
