Thread: 03 GP 3.1 Throttle body
Results 1 to 10 of 10
  1. #1 03 GP 3.1 Throttle body
    SE Level Member ssgtarivera's Avatar
    Dec 2012
    fort Worth
    From what Ive learned on just this site alone has been great.
    I assume my GP has the larger 3400 intake and wanted to find out what the stock throttle body size was and if a small upgrade could be bolted direct to the manifold without porting.
  2. #2 Re: 03 GP 3.1 Throttle body
    It's most really worth doing any upgrades to a 3100 it will still be painfully slow. If you upgrade your Tb you'll need to tune for it.
  3. #3 Re: 03 GP 3.1 Throttle body
    Not ture^^ if you just put a 3400 tb on it, the 3400 tb is like 58mm and the 3100 is like 54-55mm i think(not 100% sure but its close). You say you think it has a 3400 intake? are you talking about the manifolds? or just the tb?
    SMGPFC Member #10
  4. #4 Re: 03 GP 3.1 Throttle body
    Dec 2012
    fort Worth
    I think both upper and lower are 3400 due to the year. Is that correct or is there a way to be sure?
  5. #5 Re: 03 GP 3.1 Throttle body
    what does the top of the motor say itll say 3400 or 3100
    SMGPFC Member #10
  6. #6 Re: 03 GP 3.1 Throttle body
    new britain, ct
    it has the 3400 upper manifold.
    07 Black GXP.
  7. #7 Re: 03 GP 3.1 Throttle body
    3400 upper mani without a 3400 tb?
    SMGPFC Member #10
  8. #8 Re: 03 GP 3.1 Throttle body
    new britain, ct
    i believe so.
    07 Black GXP.
  9. #9 Re: 03 GP 3.1 Throttle body
    Dec 2012
    fort Worth
    Thanks guys. Thats exactly my thought too
  10. #10 Re: 03 GP 3.1 Throttle body
    wait what, im confused? you have a 3100 all stock but it has a 3400 upper manifold and a 3100 tb?
    oh i was wrong the 3400 tb is 4mm bigger then the stock one, the 3100 tb is 52mm and the 3400 stock tb is 56mm
    SMGPFC Member #10
  1. Throttle body
    By JAllegar in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-18-2011, 06:01 PM
  2. Throttle body in an 08
    By zenman400 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-12-2009, 09:01 AM
