Thread: UPDATE > High Idle - problem solved - IAC Valve ( Intake Air Control Valve )
Results 1 to 20 of 27
  1. #1 UPDATE > High Idle - problem solved - IAC Valve ( Intake Air Control Valve )
    Boston, MA
    2001 Pontiac GP - 3100.
    I need some help here.
    It's scary to drive this thing, need this fixed ASAP.
    In Park and Neutral, my RPM goes up to 3900 and sits there. Happens right at start up and RPMs never go down even when engine is hot.
    In Drive it goes down to 1800 and sits there.
    In Drive, if I let go of the brakes - the car takes off like a bat, due to unusually high RPM.
    When I drive this car, my foot is constantly on the BRAKES! .. not good at all.
    WTH is the matter with this thing?
    Is it an idle issue?
    A vacuum issue?
    Something else?
    Please help.
    2001 Pontiac Grand Prix SE, 3.1L
  2. #2 Re: WTH ?? -- 3900 RPM in Park & Neutral, 1800 RPM in Drive -- what gives?
    Mar 2012
    NC
    Sounds like a gigantic vacuum leak.
  3. #3 Re: WTH ?? -- 3900 RPM in Park & Neutral, 1800 RPM in Drive -- what gives?
    id start with a huge ass vac leak.( find and fix that) maybe try cleaning the TB. the butter fly flap could be sticking also.
  4. #4 Re: WTH ?? -- 3900 RPM in Park & Neutral, 1800 RPM in Drive -- what gives?
    Mar 2012
    NC
    Bring down to Quincy, and we'll diag it up.
  5. #5 Re: WTH ?? -- 3900 RPM in Park & Neutral, 1800 RPM in Drive -- what gives?
    Boston, MA
    I was thinking vacuum leak too, but the idle doesn't fluctuate - just stays there. So can it still be a vacuum leak?
  6. #6 Re: WTH ?? -- 3900 RPM in Park & Neutral, 1800 RPM in Drive -- what gives?
    SWPA
    I am not entirely sure how the cruise control is routed on that, but it could be something to do with it being stuck there. I had a similar issue on my Stealth once.
  7. #7 Re: WTH ?? -- 3900 RPM in Park & Neutral, 1800 RPM in Drive -- what gives?
    Mar 2012
    NC
    Quote Originally Posted by turboLude View Post
    Could still be big vacuum leak. Or throttle sticking open...or IAC sticking. Lots of fun things.
  8. #8 Re: WTH ?? -- 3900 RPM in Park & Neutral, 1800 RPM in Drive -- what gives?
    Boston, MA
    Quote Originally Posted by hitman92499 View Post
    What could be the source of this big vacuum leak? I just don't see how a simple loose or torn vacuum hose could cause this. What specific vacuum areas what I need to look into?
  9. #9 Re: WTH ?? -- 3900 RPM in Park & Neutral, 1800 RPM in Drive -- what gives?
    any time un metered air get into the engine the rmps can go up or down to a stall, all depends on where the vac leak is.
    the 3100 is notorious for vac leaks too.
  10. #10 Re: WTH ?? -- 3900 RPM in Park & Neutral, 1800 RPM in Drive -- what gives?
    SWPA
    The reason a vacuum leak can cause this is it is letting in air that the TB is not. The throttle body restricts incoming air to the engine. If you took the throttle body off and started the car the engine would rev til it hit its limiter.
  11. #11 Re: WTH ?? -- 3900 RPM in Park & Neutral, 1800 RPM in Drive -- what gives?
    Boston, MA
    Where can I find a vacuum diagram for my '01 3100 ?
  12. #12 Re: WTH ?? -- 3900 RPM in Park & Neutral, 1800 RPM in Drive -- what gives?
    Mar 2012
    NC
    The 3100 has lots of places for vacuum to leak. There is a hose that goes to the rear valve cover that can cause some issues, the T-hose under the bracket for the throttle body splits and leaks, plus the awesome LIM gaskets. Lots of stuff to look at. Figured since you were close by, you might want to swing down for diag, but it's all good.
  13. #13 Re: WTH ?? -- 3900 RPM in Park & Neutral, 1800 RPM in Drive -- what gives?
    you dont really need one, just follow all the small vac tubes around the engine, look for cracks or one broken off completely.
    also take your air filter tube off the TB make sure the flap is closed at idle.
  14. #14 Re: WTH ?? -- 3900 RPM in Park & Neutral, 1800 RPM in Drive -- what gives?
    Boston, MA
    Thanks for your help man. I just don't know if it's safe to drive on my brakes, I don't feel too comfortable driving more than 5 minutes like this. I'll let you know though, thanks.
  15. #15 Re: WTH ?? -- 3900 RPM in Park & Neutral, 1800 RPM in Drive -- what gives?
    Boston, MA
    Will I get a Check Engine Light for a faulty IAC valve ?
  16. #16 Re: WTH ?? -- 3900 RPM in Park & Neutral, 1800 RPM in Drive -- what gives?
    Mar 2012
    NC
    I understand. I know the feeling on driving a semi-unsafe car. LOL
  17. #17 Re: WTH ?? -- 3900 RPM in Park & Neutral, 1800 RPM in Drive -- what gives?
    it should. if your cel is on have the car scanned.
  18. #18 Re: WTH ?? -- 3900 RPM in Park & Neutral, 1800 RPM in Drive -- what gives?
    Boston, MA
    no CELs. I'm hunting blind here. Thanks for the help guys. If anyone can add to this, please do. Any guidance is appreciated.
  19. #19 Re: WTH ?? -- 3900 RPM in Park & Neutral, 1800 RPM in Drive -- what gives?
    check all that has been listed, thats all you can do for now.
  20. #20 Re: WTH ?? -- 3900 RPM in Park & Neutral, 1800 RPM in Drive -- what gives?
    Donating Users RareGMFan's Avatar
    Dec 2008
    Naperville, IL
    I have found that sometimes you do, and sometimes you don't get a service engine light with ANY sensor when it goes bad, so the light not being on doesn't rule out anything. Definitely start with the vacuum lines and check the throttle body and idle air control as suggested. Something is allowing too much air in.
    PREVIOUS: '89 Pontiac 6000 STE AWD (2/1376), '90 Pontiac GP SE McLaren Turbo (1/2749)
    '90 Pontiac Grand Prix STE McLaren Turbo (1/1000), '01 Pontiac GP GTP Special Edition (1/1341)
    CURRENT: '00 Pontiac Grand Prix GTP (ugh...boring regular one)
  1. old people CANNOT drive/park
    By sLpGPGT in forum Off Topic Discussion
    Last Post: 02-11-2012, 05:53 PM
  2. High idle in park and neutral?
    By Injectiongtp in forum General Tech Discussion
    Last Post: 04-18-2011, 05:38 PM
  3. Replies: 7
    Last Post: 07-07-2010, 08:58 AM
  4. 2006 Grand Prix tranny noise in park & neutral
    By stevencharles32 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-16-2009, 12:52 PM
  5. 01 GTP. Car shakes when in Neutral and Park.
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2008, 03:00 AM
