Thread: Need help reassembling 1999 grand prix
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #21 Re: Need help reassembling 1999 grand prix
    You have a vacuum leak. You only change the upper intake gasket which almost never fails.
  2. #22 Re: Need help reassembling 1999 grand prix
    Why did you pull the spark plug wires off anyway?
  3. #23 Re: Need help reassembling 1999 grand prix
    Houston
    What about the vac lines? Any of them get cracked while removing them? Spray some throttle body cleaner around the vac lines and the UIM while its running, and see if the motor revs higher. Also, try unplugging the MAF and see if it stays running.
  4. #24 Re: Need help reassembling 1999 grand prix
    Houston
    Not really familiar with the 3100, but this should be the vacuum diagram
  5. #25 Re: Need help reassembling 1999 grand prix
    Aug 2012
    Paragould, AR
    Ok, we will check that again, just took off two spark plugs because they were in our way, but we marked both of them
  6. #26 Re: Need help reassembling 1999 grand prix
    Aug 2012
    Paragould, AR
    Thank you so much for the pics and diagram! You have been very helpful
  1. 1999 gtp
    By GrandPrixgtp2000 in forum Members Rides
    Last Post: 02-17-2015, 10:00 PM
  2. is the 1999 grand am stereo the same as a 2001 grand prix gt?
    By llinziee in forum Audio, Security & Visual Electronics
    Last Post: 07-06-2011, 03:51 PM
  3. I need some help with my 1999 Grand Prix GTP!
    By Melissa91 in forum General Tech Discussion
    Last Post: 05-24-2011, 08:24 PM
