Thread: Do I have a Blown Head?
Results 1 to 11 of 11
  1. #1 Do I have a Blown Head?
    May 2012
    United States
    All this **** just started today so I don't think I've messed anything up too bad yet. I was heading to meet up with some friends, and my car started over heating very badly so I went home. Here are my symptoms:
    Lots of thick white smoke coming from exhaust.
    Oil cap has creamy goo on it
    Overheats quicker than it should
  2. #2 Re: Do I have a Blown Head?
    Pennsylvania
    Lower Intake Manifold Gasket
    Sport Edition Kv5 18x8
  3. #3 Re: Do I have a Blown Head?
    LIM gaskets, not head gaskets.
    They never go bad...like...ever.
  4. #4 Re: Do I have a Blown Head?
    May 2012
    United States
    Is the LIM Gasket easier to replace? Is it something I could do myself without shop tools?
  5. #5 Re: Do I have a Blown Head?
    you can do it yourself with a few wrenches and sockets. No special tools needed.
  6. #6 Re: Do I have a Blown Head?
    its a 3.1, anything coulda happened.
  7. #7 Re: Do I have a Blown Head?
    new britain, ct
    like everyone stated, its a LIM job. expect your car to be out of comission for a day. itll take a while to do if you arent well versed in mechanics.
    07 Black GXP.
  8. #8 Re: Do I have a Blown Head?
    Banned
    CT
    The key to figuring out whether it's the LIM or HG is to check for fuel or exhaust in the coolant.
    As long as you can figure out the difference between fuel and exhaust you're all set!
  9. #9 Re: Do I have a Blown Head?
    May 2012
    United States
    Quote Originally Posted by SnowFlake View Post
    how do i check that?
  10. #10 Re: Do I have a Blown Head?
    Banned
    CT
    Quote Originally Posted by kesey View Post
    billboost is the expert at determining whether it's fuel or exhaust.
  11. #11 Re: Do I have a Blown Head?
    Nice Flake..
    If you have the availability, test the compression and do a leak down test on the cylinders. That will tell you if a head gasket is bad. The most common item to go bad on a 3100 is the LIM gaskets and that would explain burning coolant etc and then not having the system bled properly due to the coolant loss can cause it to heat up.
  1. cracked head blown head gasket or just done??
    By roytoy70 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2012, 10:40 PM
  2. Blown Head Gasket??
    By InOuterSpace in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-28-2011, 08:01 PM
  3. Blown head gasket?
    By tjhgtp86 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-11-2010, 04:01 AM
  4. low, very low oil. blown head gasket or something else?
    By pontiacgp759 in forum General Tech Discussion
    Last Post: 01-04-2010, 03:51 PM
  5. blown head gasket
    By runn141 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-09-2009, 12:18 AM
