Thread: '00 3.1 SE losing oil
Results 1 to 8 of 8
  1. #1 '00 3.1 SE losing oil
    Jan 2012
    Douglasville, GA
    Hi. I am new to my 2000 SE. It has 135k miles on it and is using oil at a rate if a quart every 2,000 miles. It doesn't puddle in the drive when it's parked. Any ideas on what seal/gasket that might be failing?
  2. #2 Re: '00 3.1 SE losing oil
    So if it leaks no oil on the ground, its burning it.
    It could be going past the valve seals and getting burned up, could be getting past the rings and getting burned up. Could be a possible bad pcv causing excessive oil consumtion
  3. #3 Re: '00 3.1 SE losing oil
    new britain, ct
    you should also check the underneath of your car for any oil deposits or anything of that nature. maybe you are leaking oil from a hose and its blowing back from the wind while you are driving. just a thought.
    07 Black GXP.
  4. #4 Re: '00 3.1 SE losing oil
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    1 quart in 2000 miles is not bad at all. Find something else to worry about. Add a quart and change it at 3000 or 4000 miles.
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  5. #5 Re: '00 3.1 SE losing oil
    Your lower intake manifold gasket is most likely leaking. It's not much fun to work on but can be done in a weekend to someone that hasn't done it before.
    Jan 2012
    Douglasville, GA
    Thanks everyone. U should have mentioned there is oil residue all over the bottom end like its leaking from the top. It's hard to pin-point.
    I know it's not much to worry about an I change the oil every 4k but it bugs me nonetheless. I will follow up on all your ideas. Thanks again!
    Jan 2012
    Douglasville, GA
    Typo.... That was "I" should have mentioned the residue. :/
  8. #8 Re: '00 3.1 SE losing oil
    new britain, ct
    change it at 3k.
    07 Black GXP.
  1. Please HELP! I'm losing it here!
    By stewy58 in forum General Tech Discussion
    Last Post: 01-19-2012, 09:41 PM
  2. Losing Power!
    By Overcrazed in forum 3.1L V6 (LHO/LG8)
    Last Post: 11-11-2011, 07:13 PM
  3. Well...looks like we're losing another dragstrip.
    By alkygto in forum The Rant Forum
    Last Post: 11-14-2010, 02:30 PM
  4. i'm losing my mind... HELP
    By hodag1210 in forum General Tech Discussion
    Last Post: 08-11-2010, 11:50 PM
