Thread: 2003 3.1 different than other years?
Results 1 to 9 of 9
  1. #1 2003 3.1 different than other years?
    Cochrane
    Hi, i have a 2003 grand prix se with the 3.1L and i cant find any aftermarket parts such as throttle body spacer, cold air intake,etc. Is there a difference in the 3.1L in 2003 compared to the 97 to 02 3.1L's because they make them for those years? Any help would be much appreciated!
  2. #2 Re: 2003 3.1 different than other years?
    no theres not a difference, first you dont need a TB spacer, cause's nothing but proplems. Best would be to top swap with a 3.4/3.5 and turbo but if you dont want to go that big with it but get a stock 3400 TB, upper/lower intakes, as for the "CAI" just make your own for like 20 bucks, just search for it theres hundreds of threads about it. Next get headers Placer-setter has some some and can be found on ebay for alot cheaper. with that and a tune and you'll be just fine as a nice DD
    get out-
    Milzy Motorsports - American Muscle, Reborn
    Homepage for WOT-Tech - WOT-Tech
    60DegreeV6.com - Site News
    lots of good info on those sites
    SMGPFC Member #10
  3. #3 Re: 2003 3.1 different than other years?
    Cochrane
    Both the upper and lower intakes? And what do u mean by CAI? Thanks a lot!
  4. #4 Re: 2003 3.1 different than other years?
    yes the 60* motors have medal intakes and there 2 pieces unlike the 3800 with a plastic intake, CAI=Cold Air Intake but since its in the engine bay theres really no such thing as a Cold Air because its sucking the hot air around the engine. So its really a HAI=Hot Air Intake
    SMGPFC Member #10
  5. #5 Re: 2003 3.1 different than other years?
    Cochrane
    Ohh ok so the 3.4 lower and upper will bolt right in and hook up to everything? And whats different about them? Just larger porting?
  6. #6 Re: 2003 3.1 different than other years?
    yes bolt right up, the 3400 and 3100 are the same motor they share the same block, heads, intakes everything but the 3400 is bigger so everything on the 3400 is alittle bit bigger then the 3100 so it make for a nice and easy swap
    SMGPFC Member #10
  7. #7 Re: 2003 3.1 different than other years?
    Cochrane
    Ok thanks a lot! Where do i get a good 3.4 intake?
  8. #8 Re: 2003 3.1 different than other years?
    that first link is where i get my stuff from, there all kinda the same unless you start getting into porting
    SMGPFC Member #10
  9. #9 Re: 2003 3.1 different than other years?
    GTX Level Member 94grandprix's Avatar
    Jul 2010
    Crandall, Georgia, United States
    you sure there the same because i bought the upper intake and they said only certain years fit my 03 and my lower intake cracked but its still running strong,the only thing i can think has the 3.4 in 97-03 is the pontiac montana,grand am and the venture right and maybe monte carlo and if i find the upper and lower intake itd bolt right in no problems and does the 3.4 have anymore horses or takeoff
  1. N* TB, what years are best?
    By chunky in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-29-2011, 05:17 PM
  2. 97 GTP vs other years?
    By Pittman06 in forum General Tech Discussion
    Last Post: 11-18-2009, 09:04 PM
  3. 2003 GT vs 2003 mitsubishi eclipse GTS
    By kjohnson in forum Track Sessions and Kills
    Last Post: 04-01-2009, 11:27 AM
