Thread: car want go and hesitates someone help
Results 1 to 9 of 9
  1. #1 car want go and hesitates someone help
    lucedale
    My 2000 grand prix has been giving me problems when you first crank it up it runs good but after you go around 15-30 miles it starts hesitating and not wanting to go like its running out of gas but if I stop and cut it off and let it sit a few minutes I can go for about 5-10 miles before it starts doing it again can anyone help me figure this out thanks
  2. #2 Re: car want go and hesitates someone help
  3. #3 Re: car want go and hesitates someone help
    Ohio
    that^^
  4. #4 Re: car want go and hesitates someone help
    House springs missouri
    It could be o2s thas what happened to my old sho
  5. #5 Re: car want go and hesitates someone help
    Jan 2012
    FT Campbell, KY
    Cat, but O2 MIGHT be the culprit. Check the cat. If it is the cat, be sure to check out what made it fail. Oil? Physical damage? Fuel? Catalytic convertors don't just fail like that.
    Colleen
    : CAI, HV3, 2.5" d/p w/h/f cat. Full suspension, PowerSlots w/Hawk HPS, GR2s, Sonar projectors. Needs tune. Awaiting install of FBod brakes.
    Shianne: 98 L36 MM5. Good start to a LONG project.
  6. #6 Re: car want go and hesitates someone help
    new britain, ct
    arent our cats prone to clogging?? lol
    07 Black GXP.
  7. #7 Re: car want go and hesitates someone help
    Pennsylvania
    Quote Originally Posted by ctracer View Post
    A 13-year old cat? Well... maybe. Cats last ~150,000 miles. At 12,000/year, you're at 156,000 miles.
  8. #8 Re: car want go and hesitates someone help
    lucedale
    If it was the cat why wouldn't it run like that all the time instead of 15-30 miles of driving
  9. #9 Re: car want go and hesitates someone help
    I live here. TLSheff's Avatar
    Heat causes expansion... its a honey comb design that is probably getting clogged up, expansion causes the air way be blocked even more.
    Now, not that this may or may not be the problem, but if you have recently changed the plugs you may re-check them, I once had one crack and it didn't set off the miss-fire code but shuddered something fierce once the engine got warmed up to operating temp. just a thing to consider, and its free to check.
    do you have a check engine light on? if so, get it scanned and we can really go from there. Write the code(s) down, and let us know which ones it/they is/are.
  1. Hesitates on acceleration sometimes, gas pedal not very senitive
    By LePrix in forum General Tech Discussion
    Last Post: 10-31-2011, 06:01 PM
  2. 97 GT hesitates on acceleration and smells hot??
    By gypsyjon in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-28-2011, 09:26 PM
  3. Hesitates to start
    By kking89 in forum General Tech Discussion
    Last Post: 09-09-2011, 09:34 PM
  4. 01 GTP hesitates and lurches after expressway driving
    By tcman49 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2011, 10:55 AM
  5. Car Hesitates When Floored
    By 04GTPeeingOnU in forum General Tech Discussion
    Last Post: 07-14-2009, 07:05 AM
